June 18, 2026, 11:36:45 PM
Rough idle after fill-up **Solved**
Topic: Rough idle after fill-up **Solved** (Read 19996 times)
April 28, 2009, 05:28:53 PM »
My gas light was on this morning so I went to fill up as usual. I drive out of the gas station to a light....and I notice the car is idling very rough. I went back out in the day...same thing rough idle...and it seems to be worse when the A/C is on....and I can hear this clangy metal sound.
Did I get a bad tank of gas? Would that cause the car to idle rough? Car was fine yesterday.
Last Edit: April 29, 2009, 09:58:25 PM by clapton924
Re: Rough idle after fill-up
April 29, 2009, 01:48:16 AM »
To provide some additional info:
The rpm's are in the normal idle range. I listened to it again tonight and the roughness of the idle seems to "pulse" of sorts....but again the rpms stay steady. I think the "clanging sound" is just something metal vibrating against something in the engine bay due to the rough idle.
My friend said I should check for vacuum leaks....also said I may have gotten some gas with water in it.
April 29, 2009, 07:28:56 AM »
It is possiable that you had some stuff in the bottom of your tank that got stirred up when you were refueling. Although without hearing it, it could be anything.
April 29, 2009, 04:05:54 PM »
I drove the car today and emptied about 1/2 of the tank. I filled her up with some 93 from a shell station (my original fill was from chevron). I drove the car around to get the new gas mixed in and it still has this strange idle rattle. Only happens with car in gear sitting still. Goes away when I accelerate. Its pretty loud...makes the car sound like a beater at a stop light. The car drives fine though....I drove 70 miles on the interstate today...no issues. I wonder if something got knocked loose.
April 29, 2009, 09:56:14 PM »
Figured out the problem tonight. My cat converter is vibrating like a bitch. I have the DC sports 4-2-1 header on the car....I am guessing the flex-pipe has torn like many others...or a bolt is loose. I don't have any of my tools with me when I'm in school....suppose I will take it to a muffler shop.
Re: Rough idle after fill-up **Solved**
April 30, 2009, 01:55:18 PM »
Update: went to the exhaust shop thinking the flex pipe was broken. They put my car on the lift and we took a look. The flexpipe was fine....the cat-converter was shot...the internals were rattling around. They said it looked like the internals had started to melt....strange. To make a long story short, I had the cat converter replaced with a Magnaflow High-flow CC for $350 including labor...and they did the work in 45 min. Rattle is gone...car seems a little Peppier!
May 02, 2009, 12:46:44 PM »
Sweet! Glad to see you had a positive outcome!
03 CM55 NBP
MT
May 02, 2009, 12:50:58 PM »
Good shit. How many miles are on your car. It's not too often you hear about somebody's cat goin especially melting the internals!
May 02, 2009, 01:06:31 PM »
Quote from: "Abailey4"
The car only has 75k miles on it. Looking back on it I wish I had examined the heat shield on the CC a little more closely. The guy smacked it and I heard it rattle...but looking back on it the heat shield may have just been loose. But this guy has been doing custom exhausts for many years...and I trusted his opinion. When I called on the phone thinking my flex-pipe had separated his first response was "well, I might be able to just weld it back on"....so I don't think he was just trying to sell me something. Either way the horrid rattle is gone and I have a high-flow cat now
May 02, 2009, 07:39:23 PM »
hm. cat is part of emission system so it should be covered under emission warranty from honda i think
May 02, 2009, 11:33:16 PM »
Quote from: "AV6NHBP6SPD"
You would think so.
I checked my warranty booklet and there is a section that says "Things not covered". Exhaust and catalytic converter are the first two things listed.
May 03, 2009, 12:11:19 PM »
Clapton is correct. I can vouch for catalysts not being covered under extended warranty.
03 CM55 NBP
MT
June 04, 2010, 02:10:26 PM »
looks like i might be experiencing the same problem.
I have a borla catback exhaust with approx. 60K on it. About 2 weeks ago I starting hearing a metallic (tin like) rattling upon acceleration. Sounds like something is loose when driving about 1500-2500 RPM's. Been pissing me off for a while now.
Finally got around to taking a closer look and the noise seems to be coming from right about where the cat is. Since it is wrapped in a thin heat shield, I can almost guarantee that is what the problem is.
June 08, 2010, 06:50:02 PM »
Yeah, take a look at the heatshield....might just be loose. I wish I had checked mine before I had my entire cat replaced. I took the shops word that my cat was blown.
Silver Bullet
July 27, 2010, 10:02:57 AM »
I might have the same problem but I get this vibration or rattling when I cruise at 45 + mph but when I'm sitting, it doesn't make any sounds. I hope it's the same as yours.
2006 AV6 6MT
