October 30, 2026, 05:56:36 AM
passenger side window makes screeching noise
Topic: passenger side window makes screeching noise (Read 8837 times)
April 22, 2009, 05:10:50 PM »
my passenger side window makes a loud screeching noise when rolling down. yet the window goes up/down fine. its been like this for a few months. because of this i tend to not use that window much. but being the hot days are on the way. i need to get this fixed.
Re: passenger side window makes screeching noise
April 22, 2009, 05:15:25 PM »
clean the track.... that may help...
April 22, 2009, 05:21:54 PM »
i dont think that is it. its sound more like wolverine is running his claws down the black board..lol
April 22, 2009, 07:14:12 PM »
try some silicon spray on the track that cleared mine up
April 22, 2009, 09:24:10 PM »
try to clean the track even as suggested by others that posted before me if you haven't yet and if you dont think so. I know I had that issue before and that was the solution for me also.
K24power07
April 22, 2009, 10:20:32 PM »
Quote from: "fabulous010"
my back passenger window does the samething but not as severe as urs, but its been like that since day one when i first got it...go figure..
\_(
)_/
http]
April 22, 2009, 10:40:11 PM »
Clean the track and use some
shin-etsu grease
to lube it up. That will clear up your problem.
April 22, 2009, 11:41:01 PM »
i have some silicon spray with me. i will clean the track and spray some of that stuff on. if that doesnt work ill try to get me some grease.. thanx elite
April 23, 2009, 12:13:31 AM »
I'd skip the silicone spray. They use the shin etsu grease on the track from the factory, so there's no reason why you should do otherwise.
April 23, 2009, 08:37:45 AM »
hmmmm where can i grab that stuff? parts store, home depot, stealership?
April 23, 2009, 01:14:15 PM »
I did include a link in my first post.
April 23, 2009, 02:00:04 PM »
I second Timmy's remedy. Shin-etsu grease is very persistant and will keep the track well lubricated. If you have window tint and still experience a scraping noise, it's because you have particulates caught in the dew strip that are scratching against the tint. The most common cause for squeaky windows is a poorly lubricated track. Using silicone spray before the shin-etsu grease will decrease its effectiveness and should be avoided. Use a small paint brush to slop the stuff inside the track and then wipe the excess away after cycling the window a few times.
03 CM55 NBP
MT
