March 07, 2026, 02:33:52 AM
Author Topic: How To: Legend GS 2 piston caliper conversion on V6  (Read 41928 times)
« Reply #15 on: June 03, 2009, 03:45:28 PM »
Mine are going to under go a slight rebuilt also. The total will probably end up closer to 200
« Reply #16 on: June 03, 2009, 03:49:46 PM »
should have just gotten rebuilt once
« Reply #17 on: June 03, 2009, 06:21:58 PM »
They would have not been oem that way. I talked to the local parts stores, and the brands they offered were not that great.
« Reply #18 on: June 03, 2009, 07:05:29 PM »
ok, i dont know if you know how they do remanufacturing, they take oem rotors, change seals, if needed they check pistons to make sure they are still fine and stuff.
they dont actualy do new calipers from scratch.
i think Tim got reman and no problems with those
« Reply #19 on: June 03, 2009, 07:07:19 PM »
yeah i got a good deal also but, your right.
« Reply #20 on: June 03, 2009, 07:09:09 PM »
You had suggested that I replace some seals in mine, and sent a link can you take a look at the link you sent me and see what parts the seals are.
« Reply #21 on: June 03, 2009, 07:14:32 PM »
^^problem is that it didnt give part numbers for seals. id call acura dealer and see if they can order them
« Reply #22 on: June 03, 2009, 07:20:31 PM »
I shall
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #23 on: June 03, 2009, 08:18:26 PM »
Acura GS caliper seal kit part number- 01463-SP0-E00 $30.80ea
http://www.acuraoemparts.com/delray/jsp ... vinsrch=no
« Reply #24 on: June 13, 2009, 01:04:28 PM »
now i look at all cars while i drive to see who had 2 piston calipers
was going to Bretts house and on way there seen new TL. guess what, it has 2 piston calipers
« Reply #25 on: June 18, 2009, 10:37:05 AM »
The installation of these calipers doesn't effect the ABS in any way correct?
« Reply #26 on: June 18, 2009, 11:25:47 AM »
no it doesnt effect abs. it still works if you realy slam on brakes(jst like with regular calipers)
NVA-AV6 pfffft.
« Reply #27 on: June 18, 2009, 11:45:51 AM »
Should be picking up your caliper kits this afternoon Mike, right now the calipers are cooling down from baking.....
« Reply #28 on: June 18, 2009, 01:10:45 PM »
Quote from: "AV6NHBP6SPD"
I know that ABS works with them I was wondering if steps should be taken to ensure the ABS sesnsors and things are okay I've never replaced a caliper.
« Reply #29 on: June 18, 2009, 03:06:10 PM »
you dont touch sensors when you replace calipers so i dont think it would be a problem
