November 03, 2026, 12:41:37 AM
Author Topic: 18 inch all season tire recommendations  (Read 63434 times)
« on: April 22, 2008, 11:37:38 PM »
just wondering what would be a good recommendation for an 18in all season tires? I dont think I want to ever go back to stock wheels again....unless I get a flat.
« Reply #1 on: April 23, 2008, 12:08:44 AM »
Bridgestone Potenza RE960AS Pole Position FTW!!!
« Reply #2 on: April 23, 2008, 10:43:06 AM »
Quote from: "7thGenVillain"
+1 on the 960's.  I have been very happy with the ones on my TL wheels.  They provide good all season performance at a reasonable price.
« Reply #3 on: April 23, 2008, 06:41:33 PM »
I'm thinking of at least going 235/40/18, will 245/40/18 stick out? if so, then i'm sticking with 235/40/18.
« Reply #4 on: April 23, 2008, 07:42:14 PM »
You might also might want to take in consideration what rim width your rims are. A 235/40 R18 won't fit on a 7.5" width rim nor can a 245/40 R18 fit. If you are going say 18x8 then yes a 235 or 245 will fit comfortably and won't stick out. Tim is actually running a 245/45 R17 on his TL rims and so is Skippy.
« Reply #5 on: April 23, 2008, 09:20:16 PM »
my rims are 8.5 wide, so 245/40 R18 is fine?
« Reply #6 on: April 23, 2008, 09:23:34 PM »
If you rims are 8.5" width rim, I'd go with a 245/40 R18. I got Cham into a 245/35 R19, and he just had to raise his car a little. All and all, he doesn't rub.
« Reply #7 on: April 23, 2008, 09:45:58 PM »
well I"m planning to lower my car some more this weekend, so if I went with 245/40 R18, do you think that will rub?
« Reply #8 on: April 23, 2008, 09:51:01 PM »
You might depending on how low you go. If it does rub, you can always roll your fenders.
« Reply #9 on: April 23, 2008, 10:21:19 PM »
well I'm thinking going as low as one finger gap, whats  your observation by that? and isn't rolling fenders FTL?
« Reply #10 on: April 23, 2008, 10:29:01 PM »
With a 1 finger gap, you should be able to clear with no rubbing issue. If done professionally, then all is good. Doing it yourself, you might make mistake, and you can't go back and correct the mistake either.
« Reply #11 on: April 23, 2008, 10:41:04 PM »
sweet, then 245/40/18's it is then!
« Reply #12 on: April 23, 2008, 11:46:27 PM »
Thien, just so ya know.  I was able to fit a 235/40/18 on thost 18"x7.5" wheels.
« Reply #13 on: April 24, 2008, 12:26:26 AM »
Yeah, I know. It's not advised, but you can.
« Reply #14 on: April 24, 2008, 06:28:53 PM »
I advise a 235/40/18 on a 18"x7.5" wheel!!  As far as other diameters and profiles, I don't have any input.  I just say this because I have been safely running the 235/45/17's on my car since February.
