September 22, 2026, 07:10:37 PM
ECU, EMS, & Tuning
Exactly what you need to get Flashpro to work on the 6mt Accord 03-07 v6
Topic: Exactly what you need to get Flashpro to work on the 6mt Accord 03-07 v6 (Read 34943 times)
February 21, 2016, 05:20:20 PM »
Here is another thread made just for people who have no idea how flashpro work on the accord because the other thread sucks, and had no detail info on the front page. This will be a straight to the point and condense knowledge of what you need to buy and how to get setup.
Simples way to put it.
NO IT WILL NOT WORK ON YOUR MT STOCK ECU.
. But this is how you can get it work for your car.
Here is a buy list
1. CAN Adapter, 03-07 V6 Accord adapter
. Usually found for 350 + shipping from XLR8, Heeltoeperformance, or other performance shops
2. Flashpro for the TL
They are usually 695 new + shipping, or you can find them used on acurazine. There are probably a few hundreds of these units floating around, and most people don't sell them unless they are going back to stock or they totalled their car. Used usually go for 500-550 shipped depending if you get lucky and if you mind if the unit has bluetooth or not.
3. TL ECU 07-08 AT or MT doesn't matter
The reason why you need these 07-08 ecu is because they are made by DENSO and they have the new protocol for the CAN-BUS system which is like DSL/Cable modem speed vs the accord K-line which is like 56k. You cannot brick the 07-08 ecu when reflashing because of the way it is setup. You will just need a laptop with the flashpro software installed to fix it. Uploading map with the flashpro takes about 2-3 mins. The accord will take hours and you can brick it if you interrupt the upload. So this is why hondata choose the TL 07-08 ECU.
ECU Part Number that will work are the following:
Donor Vehicle
RDA-A83 through RDA-A84
2007 Acura TL Base Auto*
RDB-A02 through RDB-A04
2007 Acura TL MT Type-S
RDB-A11 through RDB-A12
2008 Acura TL MT Type-S
4. You will need a laptop and install the flashpro manager software
. Its ether found on the CD if you bought the flashpro unit new or on here.
https://www.hondata.com/software
How to install the flashpro
Hondata CAN adapter harness installation:
**all taken from Hondata manual
The CAN bus connector is located under the right hand side of the dash. The airbag needs to be removed to access this connector. Make sure the battery is disconnected and do not reconnect until the airbag is replaced. **Or you will die**
Connectors C3-G3 are common. Connectors C2-G3 are common.If connector row G is empty, insert the wires in the supplied green plug and insert the plug into the empty row making sure the red and connector white wires line up with those in rows C-F.
Run the other end of the adapter to the DLC. (to the left of driver’s left knee)
red and white wires that are coming from the green connectors.
Unmount the DLC connector by using a wide flathead screwdriver to press in the clips either side.
Use the supplied screwdriver to open the pin release. Slide in the screwdriver and lever upwards. There is a second pin release on the other side of the connector.
Remove the grey wire from position 14. Slide the screwdriver into the centre of the DLC connector between the catch and pin and lever off the plastic catch holding pin 14 into place. Then apply a gentle pulling pressure on the wire from behind the connector to remove the wire.
Insert the grey wire into position 1. It will only insert in one position. If you are unsure check the orientation of the pins in the same row. Your immobilizer system will still work and the car can still be driven normally. This programming wire is used only to make changes to the immobilizer system.
Insert the white wire into position 6 and Insert the red wire to position 14
What they should look like now after repinning stock vs modified
Close the pin releases and re-mount the DLC connector.
New ECU and Harness installation
Tools needed: Philips screwdriver, ratchet 10 mm socket and pry tool.
1. The TL and Accord ECU is located in the center forward section of the vehicle between the driver’s and passenger’s footwell.
2. Replace with the 07/08 TL ECU and adapter harness. The adapter harness A and E connectors must be reversed as shown in this picture.
Getting the ECU vinn and immobilizer reprogrammed
**Sorry for the ****ty video quality. I did this on my Old phone. I will probably remake some of the video in the summer
For this part you either need to drive to honda with your stock ecu and then swap the harness and ecu in. Or you can find a locksmith or someone else that can do it. **I can if you can't find someone to do it for you for cheap**
Here some video of me doing the ECU setup using my programmer.
https://www.youtube.com/watch?v=kUIfl_0zaDk
https://www.youtube.com/watch?v=5JkPPM5wgDc
Setting up the flashpro with your new ECU
https://www.youtube.com/watch?v=gG-sPSrz-rI
https://www.youtube.com/watch?v=uTzw-ZnJDx8
https://www.youtube.com/watch?v=06tOwGiUqlk
https://www.youtube.com/watch?v=FTtNIlqwHk4
MAJOR NOTE!!
Also if you are using a modified AT TL ECU 07-08 you will need to use flashpro to first lock to the ecu and then convert it to MT ECU first. Afterwards, you can get the vinn and immoblizer programmed. The reason for this is because when you go to acura/honda to do the ecu setup. It will ask for you to depress the clutch. Since the AT ecu does not have a clutch it will not complete the cycle, and the tech will say that it has failed or the ecu is damaged because it cannot complete the sequence. After you get the ECU programmed you can then use flashpro to unlock the ecu again and then relock it so that the vinn matches your car. Or you can leave it as is. I believe that the flashpro locks onto a binary bin instead of just the vinn number.
Tuning
The base map that comes with the flashpro is very basic. It is just enough for you to drive around town to get to your Tuner or to do an Etune (electronic tuning by using datalogs). Do not try to go WOT on this map because your car will just run like ****.
Also if you guys want to share some Maps you can uploaded here and password protect it. So whenever someone wants to borrow one. They need to ask for your permission first. But for people using other people maps. If your car blows up because you used other people map that your (guy downloading problem). Every car is different and everyone map is fine tuned to their specific car.
Please list the mods you have with the maps. I will upload mine, but I doubt anyone but myself is running an aquamist system on their N/A J30a5 and a swapped PNP TLS head
Last Edit: March 07, 2016, 04:42:45 PM by thisaznboi88
Re: Exactly what you need to get Flashpro to work on the 6mt Accord 03-07 v6
February 21, 2016, 05:20:47 PM »
[COLOR="Red"]**Disclaimer, use my maps at your own risk** By accepting my password for the maps I assume no liability for damages or bodily harm that might result from blown engine, accidents, and act of god that may occur.
[/COLOR]
Dyno tuned Map:
Mod: ATLP v1, Magnaflow catback, aquamist w/m injection size M4 nozzle, 3.5L Magnesium IM, 3in Paul SRI, MDX 310cc injectors, PnP runners, PnP heads TLS cylinder heads, MDX/TLS camshaft and valvetrain, HFPC, UR underdrive pulley, MDX riser, P2R thermal gasket, and P2R throttle body spacer
https://www.dropbox.com/s/fsfqey2pwbj0omv/J30_NA_IMWTUNE.rar?dl=0
Street tuned map post dyno
Mod: Richie V3, Magnaflow catback with 2.5in flange, aquamist w/m injection size M4 nozzle, 3.5L Magnesium IM, 3in Paul SRI, RDX 410cc injectors, PnP runners, PnP heads TLS cylinder heads, MDX/TLS camshaft and valvetrain, HFPC, UR underdrive pulley, MDX riser, P2R thermal gasket, and P2R throttle body spacer
https://www.dropbox.com/s/z5axzyxoaefpa0r/Ken%20Post%20Dyno%20RDX.rar?dl=0
Turbo Street Tuned Map Pre-dyno
Mod: Custom turbo down pipe, Holset hx35 turbo with custom Garrett .62AR turbine housing, Downpipe 3in with ventus funnel to 2.5in 3 bolt flange, Magnaflow catback with 2.5in flange, aquamist w/m injection size M4 nozzle, 3.5L Magnesium IM, 4 inch K&N Intake filter Pod, RDX 410cc injectors, PnP runners, PnP heads TLS cylinder heads, MDX/TLS camshaft and valvetrain, HFPC, UR underdrive pulley, MDX riser, P2R thermal gasket, and P2R throttle body spacer.
**pending installation of turbo**
February 21, 2016, 07:24:58 PM »
Stickied. Good thread Ken.
February 21, 2016, 09:23:15 PM »
Great information, and phenomenal photos.
February 22, 2016, 12:12:19 AM »
Thanks guys. all the photos were taken from Hondata manual that why they look so clean. The videos I will try to tweak later since I have a better phone to do so know.
