September 28, 2026, 04:35:13 PM
Check Engine Light Codes Discussion
Topic: Check Engine Light Codes Discussion (Read 175505 times)
Re: Check Engine Light Codes Discussion
Reply #30 on:
July 02, 2009, 01:27:08 PM »
Quote from: "Icebox"
that sounds like the code would be caused by a dirty maf sensor or a vacuum leak not the sensors on the exhaust.
Well the code continuously is P0171...
Reply #31 on:
July 02, 2009, 01:54:01 PM »
my sisters lex pulled that code, i cleaned the maf sensor and havent had any problems since. google that code and see what returns.
Reply #32 on:
September 09, 2009, 08:22:08 PM »
the cel code p0171 keeps popping up on my car, but then goes away for awhile. its used to appear for a couple days. and then disappear for a couple weeks. now it shuffles between days, on and off. my guess is a dirty maf sensor. if it was a bad o2 or a/f sensor then the code would just stay on...?
InFuMoUs
Reply #33 on:
September 09, 2009, 08:40:09 PM »
Well that code you just listed points to the O2 sensor in ya header. If it was bad it usually stays on, but my guess would be there's some kind of short in the wire which could explain why it keeps coming on and goin off. You can try cleaning the MAF, but not sure if that will help solve the issue.
Steve -
Squad/
Team Crazy Creashunz
Reply #34 on:
September 09, 2009, 09:03:22 PM »
My CEL went on and off for a while then stayed on when it was the O2 sensor.
Reply #35 on:
September 09, 2009, 09:09:16 PM »
i will try to clean up the maf sensor and check for any leaks on my intake. then i will reset my ecu and see if it appears again.....
none of this happened right until i switched the accord manifold for the tsx IM. the same day i switched the two i got a cel code. then went away and never came back. then i installed a CAI and it re appeared and keeps popping on and off now. i am going to plug in a code reader just to make sure it is that code..
InFuMoUs
Reply #36 on:
September 09, 2009, 11:03:46 PM »
Sounds like the MAF is freaking out by the increase air flow it's been getting.
Steve -
Squad/
Reply #37 on:
September 09, 2009, 11:55:28 PM »
P0171= fuel system too lean
You may want to try resetting your ECU, doing the idle learn procedure, and consider filling up with premium for the next tank of gas.
Reply #38 on:
September 10, 2009, 05:55:26 PM »
hmmm ok i have reseted the ecu b4 like skip had mentioned. i will try reseting it again, erasing the code and then filling up with premuim.
would having to much air in and not enough out cause this too? i have the tsx IM and CAI, but stock exhaust and headers...
Reply #39 on:
September 10, 2009, 09:54:30 PM »
I never had the problem when all I had was a CAI and TSX IM. I also do not have a MAF.
Reply #40 on:
September 11, 2009, 06:35:26 PM »
could that fact that i have a maF make a difference? anyways i dont have much time. but im going to put premium gas, maybe in 94 octane:D on sunday i will probably clean out the maf and check for any leaks on the intake. i really need a code reader to plug in tho.
Reply #41 on:
September 12, 2009, 09:52:24 AM »
TIM ONCE AGAIN! YOU ARE A FUCKING GENIUS! last night i needed to fuel up. so before i tried anything else i pumped premium fuel like you said. and BANG as soon as i started the car i reset my odometer, then remmebered to check the cel light and it was gone!!! tim once again you have come thru for me. your the man bro. thanx alot
Reply #42 on:
September 15, 2009, 05:38:34 PM »
over the weekend the cel code popped up again. so i tightened up my intake manifold (one bolt needed to be tightened 1/4 turn) plugged in the code reader and erased the code..(p0171) so far so good.
it actually read 2 codes p0171 and p0171 p. what does this 'p' stand for? pending>?
Reply #43 on:
September 15, 2009, 05:48:23 PM »
The "p" stands for pooty-tang.
Seriously though, I don't know why you would get the same code twice. Maybe its a Canadian thing.
Reply #44 on:
September 15, 2009, 06:03:06 PM »
hahaha. i dont know either. can someone clarify whats the p stands for?
