August 06, 2026, 06:23:30 AM
Clutch fluid replacement
Topic: Clutch fluid replacement (Read 7945 times)
SilverAccords06n12
March 30, 2014, 08:41:41 AM »
I thought I had clutch fluid replacement instructions bookmarked, but I was wrong. Now I can't find anything when I search. Can anybody point me in the right direction? I am led to believe there is a drain valve under the car somewhere for a 5mt clutch. Any help would be appreciated!
Re: Clutch fluid replacement
March 30, 2014, 10:41:11 AM »
The valve is on the slave cylinder, which is on the front of the transmission. You'll see it under the intake piping to the air box. I can post a diagram later tonight if you need more help.
Feel free to PM if you need to.
SilverAccords06n12
March 30, 2014, 11:05:06 AM »
Thank you sir. I'm pretty sure I can find a write up or diagram pointing out where the slave cylinder is, I just needed a little nudge in the right direction. I'm gonna take care of the fluid change today, so I will PM you if I screw it up or have questions
March 30, 2014, 02:59:06 PM »
Sounds good man. Good luck.
