August 21, 2026, 08:46:43 AM
CT Engineering Supercharger [Update with Vids]
Topic: CT Engineering Supercharger [Update with Vids] (Read 39651 times)
Re: CT Engineering Supercharger [Update with Vids]
Reply #60 on:
April 12, 2009, 09:22:55 PM »
updated
seththekorean
Reply #61 on:
April 12, 2009, 09:26:49 PM »
Nice numbers there Thien.
[size=150]
Seth
[/size]
04' Coupe k24a4 5AT
SECM Squad Member
mnkyman
Reply #62 on:
April 12, 2009, 09:38:45 PM »
someone correct me if i'm wrong, but what is the point of a tune in very cold weather when the average temperature the car will be at is much higher? I understand doing a dyno in colder weather (better numbers), but why a tune?...do you have different maps you can switch between?
Sam
-|- 2006 I4 Sedan SE
Reply #63 on:
April 12, 2009, 10:09:27 PM »
Whenever you modify your engine with more than just bolt ons, you need to tune it. If you don't tune your motor, you're going to run rich or lean (depending on the modification) and will damage your motor. In Thien's case, he was running incredibly lean because the SC was forcing more air in the combustion chamber, but the stock ECU was not providing enough fuel to compensate for the forced induction.
Reply #64 on:
April 12, 2009, 10:20:03 PM »
What Tim said.
mnkyman
Reply #65 on:
April 12, 2009, 10:25:23 PM »
i understand that, but shouldn't you tune at temperature that the car is going to be running at a majority of the time?
It just doesn't make sense to go get a tune at 40 degrees, when summer is just around the corner and the car is going to be driven in much warmer weather.
Sam
Reply #66 on:
April 12, 2009, 11:07:10 PM »
I guess you don't get the point of tuning then Sam. If he didn't tune his car, he would DAMAGE THE MOTOR! Isn't that reason enough to tune it as soon as possible? Sure, different temperatures can affect the performance, and fine tuning it for those changes is good practice. But think white and get serious. Engine reliability trumps performance.
mnkyman
Reply #67 on:
April 12, 2009, 11:48:41 PM »
what the hell is that suppose to mean?
He has had the SC for atleast a month now, has this seriously been the warmest day? If keeping the engine from blowing up was a major concern, I would figure he would do that within the first couple days (if not immediately after)...
and just for the record, i understand that a tune is important, im advocating that he should have tuned a long time ago...not a month later on a cold day
Sam
Reply #68 on:
April 13, 2009, 12:03:12 AM »
OK, It was tuned 2-3 week ago. The shop that did the tune half assed it. So, I took it to another shop. I scheduled the dyno and tune for today, but I scheduled it 2 weeks ago. I did not think it was going to be 40 degrees out. Sorry, I don't live in Texas where its hot and has a steady weather condition. Here in Colorado, it snows in April and/or in May, and you will never know if it'll snow or not.
mnkyman
Reply #69 on:
April 13, 2009, 12:19:27 AM »
Quote from: "MyNameIsThien"
that's what i wanted to know...i knew your were smarter than letting your car run for over a month without a tune
Sam
RTexasF
Reply #70 on:
April 16, 2009, 11:52:37 AM »
Beyond impressive.......way beyond. I'm curious how tough the torque steer will be to control. Will you be using a 5W30 synthetic oil?
Rick, token old bastard.
Reply #71 on:
April 16, 2009, 09:16:01 PM »
I am making the switch next oil change from Mobile 1 5W20 to Mobile 1 5W30. As for the torque steer, it does get a little crazy if I put the pedal to the medal.
khmerbodian
Reply #72 on:
February 13, 2010, 10:35:56 PM »
nice looking accord !
neoryan7
Reply #73 on:
March 08, 2010, 02:48:06 PM »
Looks great! I noticed you did a cluster swap too? how hard was that?
Reply #74 on:
March 08, 2010, 08:09:37 PM »
I didn't do a cluster swap.
