November 04, 2026, 05:50:59 PM
Wiper review and maintenance
Topic: Wiper review and maintenance (Read 45586 times)
Re: Wiper review and maintenance
Reply #30 on:
February 05, 2012, 08:57:43 PM »
Actually, I was saying that the rubber inserts should cost about $8 total. The driver's side wiper part number is 76620-SDA-A01 and the passenger's side wiper part number is 76630-SDA-A01. They should both cost about $24 total. I'll PM you the email for Ryan at AFH to see what they can offer you for prices.
Re: Re: Wiper review and maintenance
Reply #31 on:
February 05, 2012, 09:09:17 PM »
I knew that.
mnkyman
Reply #32 on:
February 06, 2012, 12:11:08 AM »
Thanks for the info and contact email Tim! Just shot him a PM!
Sam
-|- 2006 I4 Sedan SE
Reply #33 on:
July 29, 2013, 05:07:07 PM »
Totally not going with Bosch Icons again. The driver's side wiper leaves about a 12" diameter circle of unwiped space. I'll attempt cleaning the windshield and wipers better, but I'm fairly certain this issue is unavoidable.
OEM inserts here I come!
Reply #34 on:
July 29, 2013, 07:50:09 PM »
I've been using valeo's from tire rack with pretty decent results. I've had my pair for like the last 2 years and they still work. I should replace them soon though.
Re: Re: Re: Re: Wiper review and maintenance
Reply #35 on:
July 29, 2013, 08:25:13 PM »
Quote from: Jeff on July 29, 2013, 05:07:07 PM
You removed that bracket on the underside of the DS arm? I've seen that happen and in most cases removing the bracket fixes the gap problem.
I use Icons and I swear by em. Last set lasted 3 years. I just wipe down the actual blade every months to make sure its clean.
Reply #36 on:
July 29, 2013, 10:39:26 PM »
Quote from: accordguy04 on July 29, 2013, 08:25:13 PM
Hmm, I don't recall what bracket you're talking about... the old wiper comes off with the clip thing, and the new one goes on with its own clip thing. I'll have to take a look sometime. Where is this bracket located exactly?
Reply #37 on:
July 29, 2013, 11:30:49 PM »
About halfway on the wiper arm on the underside. Its shaped like a U and is held on by a screw.
Reply #38 on:
July 30, 2013, 12:09:18 AM »
Ohhhh, I just noticed it after getting in my car like 5 seconds ago. That shit is coming off pronto!
Reply #39 on:
July 30, 2013, 08:03:48 AM »
Use a #2 Phillips.
Reply #40 on:
July 30, 2013, 09:37:14 AM »
That did the trick. It works perfectly now. Thanks guys.
Reply #41 on:
July 30, 2013, 10:24:51 AM »
No problem.
Reply #42 on:
July 30, 2013, 11:41:32 AM »
wish i had known about this fix, i gave up on the icons at least 6 months ago.
Reply #43 on:
July 30, 2013, 01:16:53 PM »
Other than the missed spot, these blades work very well. I think now that the issue is resolved, I'll consider sticking with this brand. Only time will tell for how long they'll last though.
