September 21, 2026, 03:54:43 AM
Dome light
Topic: Dome light (Read 23130 times)
accordcoupe7
Dome light
August 17, 2013, 11:56:04 AM »
So I tried to wire some lights to the green/red wire in the dome light so that it comes on when I lock/unlock the car && open the door. However the lights stay on, even after the dome light turns off. What should I do?
Re: Dome light
August 18, 2013, 11:44:52 AM »
Doesn't it do that already without having to modify anything?
accordcoupe7
Re: Dome light
August 18, 2013, 02:06:50 PM »
Quote from: gargantula99 on August 18, 2013, 11:44:52 AM
i meant i was wiring interior lights TO the dome light so it turns on with the dome light when i open and close the door.
Dome light
August 18, 2013, 03:20:42 PM »
Oh I see. Maybe Tim could help you with that. He's good with understanding the wiring on these cars. I think the switch might have something to do with it. If it werent for the switch the dome light would be on all the time since there's constant power going to it.
Re: Dome light
August 18, 2013, 04:19:10 PM »
How did you have the lights wired to the green/red dome light wire?
accordcoupe7
Re: Dome light
August 18, 2013, 09:11:14 PM »
I used a quick splice to connect to the green/red wire
Re: Dome light
August 19, 2013, 12:23:00 AM »
Did you run the ground wire to the green/red wire? Where did you wire the 12v for your lights?
accordcoupe7
Re: Dome light
August 19, 2013, 12:39:07 AM »
Quote from: timot_one on August 19, 2013, 12:23:00 AM
Oh wait I'm suppose to wire the ground to the green/red? I wire the 12v to that. Was that the problem?
Re: Dome light
August 19, 2013, 01:06:15 PM »
Yes. The green/red wire is a grounding wire.
accordcoupe7
Re: Dome light
August 19, 2013, 01:50:46 PM »
Quote from: timot_one on August 19, 2013, 01:06:15 PM
Oh okay. So where should I route my 12v wire?
Re: Re: Dome light
August 19, 2013, 02:03:56 PM »
Wait, so if your positive was hooked to the grounded dome wire, and your negative was grounded as well, how did it work in the first place?
accordcoupe7
Re: Dome light
August 19, 2013, 02:07:57 PM »
Quote from: Jeff on August 19, 2013, 02:03:56 PM
Lol good question. I have no idea. Is green/red really ground? Not the white one?
accordcoupe7
Re: Dome light
August 20, 2013, 10:33:07 AM »
Quote from: accordcoupe7 on August 19, 2013, 02:07:57 PM
Any ideas guyss???
Re: Dome light
August 20, 2013, 11:56:50 AM »
There is a wiring guide that is stickied in this forum. I will look at the wiring diagram later tonight when I get home and try to help you out.
accordcoupe7
Re: Dome light
August 20, 2013, 02:15:40 PM »
Quote from: timot_one on August 20, 2013, 11:56:50 AM
Thanks ! Really there is?? If I knew that I would have looked. But I'm still getting used to the new tapatalk app. Lol
