January 28, 2026, 07:25:09 PM
Engine Problems, Car wont start on random moments.
Topic: Engine Problems, Car wont start on random moments. (Read 35646 times)
theycallme_og
not that kind of OG
Re: Engine Problems, Car wont start on random moments.
April 25, 2013, 07:46:36 PM »
all stock exhaust, its my DD..
April 25, 2013, 08:48:49 PM »
Cleaning
your cat probably won't do a thing. I'm not really sure how you would clean a catalytic converter anyway. Basically, your catalytic converter isn't doing it's job. You can either replace the cat with a new one, or get one of those O2 sensor spacer/extender things.
hondaguy214
April 25, 2013, 11:11:41 PM »
I would reset the light and drive it see what happens.
NECM
SQUAD
#6
hondaguy214
April 25, 2013, 11:13:26 PM »
But Easy test you can do jack up the car and let it run until normal operating temperature. Take a temp meter and check temp before the cat pipe and after the cat. There should be a difference in temperatures, if temps are the same cat could be bad
NECM
SQUAD
#6
theycallme_og
not that kind of OG
April 26, 2013, 11:20:09 PM »
OK Guys, really need major help.... Forget about that Check Engine Light
Tried to start my car today and NOTHING....
First symptoms looked like a weak battery with weak cranking and then no cranking just a clicking.
So I took off the alternator to get it tested and its works just fine.. Tested the battery again and it works.
I tried jumping the car and it still wont turn on..
Could it be a Relay, Fuse,
HELP
April 27, 2013, 06:30:55 AM »
Probably starter if battery and alt good.
April 27, 2013, 09:06:04 AM »
I agree with Paul.
Re: Re: Engine Problems, Car wont start on random moments.
April 27, 2013, 10:18:30 AM »
He said he had it checked. Don't we have a main relay floating around in the dash like older Honda's? I know that being an issue on them so not sure if that fits with this situation.
theycallme_og
not that kind of OG
Reply #23 on:
April 27, 2013, 12:49:21 PM »
I found this online I will be checking them out later today
http://www.webanswers.com/automobiles/maintenance-repairs/weres-is-the-main-relay-for-my-2003-honda-accord-b59ac7
hondaguy214
Reply #24 on:
April 27, 2013, 11:58:55 PM »
Does your immobilized light flash? The green one? When the key is in ignition?
NECM
SQUAD
#6
Reply #25 on:
April 28, 2013, 09:41:28 PM »
No we do not have a "main relay" like the older hondas, they broke it out into two standard relays in the drivers fuse box starting with the 7th gen.
Until you turn the key to the on position and power the ECU and Immobi Transponder , yes, but based on your description of the starter just clicking with a good battery I am still pointing at the starter.
Re: Re: Re: Engine Problems, Car wont start on random moments.
Reply #26 on:
April 28, 2013, 10:31:44 PM »
Quote from: NVA-AV6 on April 28, 2013, 09:41:28 PM
I wasn't sure whether we did or not. Thanks for the clarification Paul.
theycallme_og
not that kind of OG
Reply #27 on:
April 29, 2013, 01:58:55 AM »
I will be buying a new starter tomorrow, to give it a try.. I also believe the starter is no good..
will keep you guys posted.
theycallme_og
not that kind of OG
Reply #28 on:
April 30, 2013, 01:10:14 AM »
The Verdict is in, it’s the Starter.
Just want to thank everyone for the help. Really glad I didn’t have to take it to shop and pay a huge fee.
theycallme_og
not that kind of OG
Reply #29 on:
May 07, 2013, 02:03:53 PM »
Also another recap on the Check Engine light, "P0420".
Well rather then biting the bullet and paying $700 for a new CAT. I thought it wouldn’t hurt to try and clean the CAT. So I pulled out theCAT, blew air into it with a air gun then soaked the CAT in hot soapy water for an hour or so, then ran water threw it several times, blew air again to dry it. Put it back into the car and the check engine vanished immediately, and I did not remove the battery..
So I am very happy that worked out for me.
Last Edit: May 07, 2013, 02:06:13 PM by theycallme_og
