August 25, 2026, 09:15:59 AM
Ported Intake Runners
Topic: Ported Intake Runners (Read 9451 times)
Povy
February 22, 2013, 10:56:42 PM »
So I have ported two sets of runners. The first being from a TSX (which will not work on our accords) The second being the OEM runners that were on my CM5
The TSX runners I ported out to 2-1/8'' where the stock diameter was just under 2". Doesn't seem like a lot but There were definitely noticable gains.
Now the reason the TSX runners/inj base will NOT work on the Accords is because the TSX does not recycle the exhaust gases through the runners like the Accord does. There are only four small ports in the runners on the TSX set. On the Accord however for "maximum efficiency" the exhaust gases are dumped into the runners via four large ports right at the top of the runners where it connects to the intake manifold. I think the TSX doesn't have these because they have Vtec on the exhaust side so they just dump it. Because when i blow into the hole that should be where the EGR gases flow through its blocked somewhere internally. On the accords it's free flowing.
Anyways So since i threw a CEL for "Exhaust gas recirculation insufficient" I went ahead and ported out the OEM set from my car.
These I ported out to 2-3/8" which was significantly larger than the stock size. I have these paired along with Ralco Stock Diameter lightweight pulleys, TSX IM, TB, and weapon-R secret weapon intake. Love the results! booty dyno definitely likes it and the engine literally ROARS when vtec engages.
pics
Accord Runner stamp
TSX Runner Stamp
First set (TSX)
Second set (Accord)
This one was ported more after pic was taken
Comparison of stock and ported runners
Went ahead and bought a thermal Gasket from Zerg
Before PNP
After
Questions Comments Likes and dislikes welcome
Last Edit: February 22, 2013, 11:01:06 PM by Povy
fatbastard
Re: Ported Intake Runners
March 10, 2013, 09:17:45 AM »
i wish you had before and after dyno graphs or 0-60 time slips for these mods.
people here swear by gains from the TSX IM (me included) so i dunno if the gains you've felt can be attibuted to it or the ported runners. anyone with any ideas?
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
Povy
March 10, 2013, 10:06:54 AM »
You and me both
I already had the TSX IM on for over a year. Then last fall found a deal on the TSX throttle body. So I think the combo has helped a lot. But yes I agree I'd love to get some dyno runs in but just wish it was a standard.
After letting the ECU get used to the new mods here's another video.
Last Edit: March 10, 2013, 10:11:54 AM by Povy
March 10, 2013, 11:43:53 AM »
Did you port match the runners to the gasket? Was there any overlap on the intake ports on the head. Sometimes if there is an
edge
it can create turbulence and hurt power.
Povy
March 12, 2013, 09:41:58 AM »
Quote from: timot_one on March 10, 2013, 11:43:53 AM
edge
Yes sir! Gasket matched and pretty dang close to the head match.
The intake ports on the head are ever so slightly larger than the runners. I plan on going in later and matching up the head and fine polish the runners for even better flow. The only reason I hadn't done that to this set was I was under time constraints to get it finished. Dang college life.
Last Edit: March 12, 2013, 09:52:09 AM by Povy
