September 20, 2026, 01:01:42 PM
Pages: « First < Previous 1 ... 36 37 [38] 39 40 ... 43 Next > Last »   Go Down
Author Topic: Audio/Video Q&A Thread  (Read 399005 times)
« Reply #555 on: August 08, 2013, 01:29:26 AM »
I can look that up for you.  If you're hearing something knocking from under the stereo, you should probably look into that first.  Honestly, the ECU wouldn't really be affected by something like this.
« Reply #556 on: August 08, 2013, 06:59:00 AM »
Tim would you think the multiplex control unit could be the issue if all else fails?
« Reply #557 on: August 08, 2013, 07:11:19 AM »
That would be great
That is what I had hoped.  It is hard to pinpoint exactly where the noise is coming from.  I'll have to remove a couple dash panels this weekend and take a closer look.
« Reply #558 on: August 08, 2013, 11:29:37 PM »
Sure.  Stranger things have happened.
« Reply #559 on: August 09, 2013, 01:09:50 PM »
Well I figured out where the sound was coming from, although I have no idea what it does.  According to the parts diagram, it is a "Stopper" (54023-S5D-A81).
It only does this clicking when in park, without the brake applied.  If I apply the brakes, or shift out of park, it does not do this.
Video:
« Reply #560 on: August 09, 2013, 03:06:37 PM »
Mine clicks to.
« Reply #561 on: August 09, 2013, 03:34:21 PM »
Only when the blinker is on and in rhythm with it?
« Reply #562 on: August 10, 2013, 08:26:31 AM »
Nope different click. Mines random like a fucking gremlin.
« Reply #563 on: August 14, 2013, 07:31:12 AM »
Swapped the combination switch, still no change.
When I put the car into reverse, both blinker lights on the dash briefly light up.   The image on my HU from the rear view camera is very distorted and basically fucked up.
Could a faulty rear view camera be causing all these problems?  I hate to keep throwing money at this by replacing things but I'm running out of ideas...
There is an auto electrical repair shop near my house that I'm going to take the car to if I can't figure it out.  I'm just not looking forward to spending hundreds of dollars for them to try and diagnose the problem.
« Reply #564 on: August 19, 2013, 07:50:52 AM »
Checked the rear view camera wiring, the tail light wiring, and the head light wiring and harness. All looked fine.  I tested every single fuse in the car and all tested fine.  I checked every single ground wire in the engine bay and they were all were fine.  I pulled the stereo out and redid EVERY single fucking wire.  Nothing worked.
I think I've done everything I can, time to take it somewhere I guess...   Cry
« Reply #565 on: August 20, 2013, 09:28:25 AM »
Okay so completely different question.  I think my rear view camera is bad and I bought a replacement.  The camera itself is the same but the wire harness is different.
On the old camera harness, at the end that plugs into the headunit, there is a little red wire coming out that connected to the  Reverse sensor wire of my headunit.  The new cable does not have this red wire.  So what do I connect to the reverse sensor wire, or do I just leave it disconnected?
« Reply #566 on: August 20, 2013, 01:02:47 PM »
Is that reverse sensor wire on your head unit hooked up to your reverse lights?
« Reply #567 on: August 20, 2013, 01:44:52 PM »
No, the reverse sensor wire on my head unit is connected to the little red wire that comes out of the camera's yellow connector that plugs into my head unit.
here is a picture
« Reply #568 on: August 20, 2013, 10:32:11 PM »
So, what do you have triggering your head unit to switch to the reverse camera?
« Reply #569 on: August 21, 2013, 07:22:50 AM »
That little red wire coming from the yellow connector.
Pages: « First < Previous 1 ... 36 37 [38] 39 40 ... 43 Next > Last »   Go Up
