November 04, 2026, 10:31:01 PM
Audio Systems
Audio/Video Q&A Thread
31
32
33
34
43
Topic: Audio/Video Q&A Thread (Read 410288 times)
Re: Re: Re: Audio/Video Q&A Thread
Reply #465 on:
September 25, 2012, 11:19:36 AM »
Quote from: ikethegreat on September 24, 2012, 09:08:14 AM
Quote from: CrackerTeg on September 21, 2012, 03:37:43 PM
I'm not surprised the company isn't around anymore. Was the old camera the type that goes above the plate or was it a license plate light replacement type?
Above the plate type.
Is the connection to your rear view cam look like a aux 3.5 mm cable ?
Reply #466 on:
September 25, 2012, 01:28:57 PM »
I really have no idea. These are the only wires I see in the trunk for the camera.
I'm tempted to just buy a camera then just have a local shop install it to avoid any hassles with having to redo the installation.
Reply #467 on:
September 25, 2012, 01:58:04 PM »
That one connector to the right with no tape on it looks just like what Clemente is talking about.
Reply #468 on:
September 25, 2012, 11:06:39 PM »
Because it looks like my spare there all over ebay but i got mines off some chines distributors site till i found the one i liked ,there pretty durable and easy to swap this one is all metal and more durable then the knock offs part # is E360
Reply #469 on:
September 25, 2012, 11:16:24 PM »
That looks like the one I want too, found it on ebay!
Reply #470 on:
September 25, 2012, 11:19:57 PM »
yeah fits good with out drilling and the angle is perfect once center , Tmart sells the higher quality ones
Reply #471 on:
September 26, 2012, 07:51:56 AM »
Thanks man, I'll look that one up.
Reply #472 on:
September 26, 2012, 07:58:35 AM »
I think that one will work perfectly. The wires look the same.
Reply #473 on:
September 28, 2012, 12:45:02 PM »
Tim. Read this in ubermike's profile thread.
Quote from: timot_one on September 27, 2012, 04:53:08 PM
80 Hz is a good crossover point for the front speakers actually. You'll have more midbass up front, which will fool your brain to localizing the bass in front of you instead of behind you. The higher you have your subwoofer crossover set, the easier it will be to localize where the bass is coming from.
I did not change the crossover frequency from 80Hz. When setting the crossover frequency, it also allows adjustment of +/- 6 from the base frequency (i.e. my HU has base frequency settings of 60 Hz, 80Hz and 125Hz). Should I also make that additional detailed adjustment? If yes, what settings would you recommend?
Last Edit: September 28, 2012, 01:16:58 PM by HEcreated487
Reply #474 on:
September 28, 2012, 09:51:39 PM »
Are you talking about the crossover slope? If you can set the crossover frequency and slope for the interior speakers (front and rear independently) and the sub on the head unit, then you're in good shape. If it were my set up, I'd have the front speaker crossover frequency set at 80 Hz with a -3 dB slope, the rear speaker crossover frequency at 125 Hz with a -3 dB slope, and the sub crossover frequency at 80 Hz with a -3 dB slope.
If you can only set the interior speakers and not the sub, then you will need to figure out if your sub amp has an adjustable or fixed crossover slope. Usually it's fixed. If it's fixed, you'll need to figure out what the slope is. Would you happen to have a link to the owners manual of your head unit?
Reply #475 on:
September 30, 2012, 10:12:08 PM »
Pretty sure its the crossover frequency. I'll take a look at your suggestions and see what my HU is capable of. I have the link for the HU's owner's manual saved somewhere, Tim. I'll edit this post when I find it. Thx for the other info; very much appreciated.
Reply #476 on:
September 30, 2012, 11:47:14 PM »
That's odd. Doesn't make sense to me why you would be able to adjust it +/- 6 Hz. At those frequencies, you won't be able to tell a difference.
Reply #477 on:
October 01, 2012, 12:40:26 AM »
Well, I'm an audio n00b, so I could just be incorrectly stating some things. Just know the real basics. The manual should explain more. Will get that info ASAP.
Reply #478 on:
October 01, 2012, 01:49:36 AM »
Cool man.
Reply #479 on:
October 04, 2012, 02:39:55 PM »
While messing around with my rear view camera, I came across a connecter that wasn't plugged into anything. I don't see anything near it to plug into, any ideas what it is for?
31
32
33
34
43
