November 04, 2026, 10:30:59 PM
Audio Systems
Audio/Video Q&A Thread
30
31
32
33
43
Topic: Audio/Video Q&A Thread (Read 410287 times)
Re: Audio/Video Q&A Thread
Reply #450 on:
September 21, 2012, 10:14:45 AM »
And just so I don't fuck something up, where do I even plug it in at?
Reply #451 on:
September 21, 2012, 10:25:50 AM »
We may need to figure out how the shop fucked up your set up. It seems like they are lazy. Anyway, the best way to do it is to plug the cable into the AMP1 RCA inputs. Don't spend much on the cable also. Get the cheapest one you can find. Also, make sure the iPod volume is turned all the way down when you start out and slowly raise the volume. I'll PM you my number if you have any questions while you're doing this.
Reply #452 on:
September 21, 2012, 10:25:51 AM »
Plug in right where it says input. If you have multiple RCA inputs, unplug them (remember where they came from obviously) and plug that adapter in you posted. If you get sound, from the amp->out is good. Matter of fact, you may be able to do it from the 360 but I'm not familiar with the inputs of it.
Edit-Tim beat me to it.
Reply #453 on:
September 21, 2012, 10:27:46 AM »
The 360 is really pointless because it's basically a higher end line level converter. Since he's using an aftermarket h/u, it's useless. The shop was lazy and didn't want to do the work.
Reply #454 on:
September 21, 2012, 10:33:14 AM »
Thanks guys I'll try this and Tim I'll give you a call if I have any problems.
Reply #455 on:
September 21, 2012, 01:31:40 PM »
Well I looked at everything again before I went and bought anything and I'm glad I did. My capacitor looks like it took a beating during the accident and apparently one of the power wires slipped out of the terminal. I didn't notice it yesterday because it was still in the shrink wrap tubing but just barely touching the terminal, which I guess is why it would work for a second sometimes. I'm just glad for once it was an easy fix!
Thanks for the help fellas
Reply #456 on:
September 21, 2012, 01:45:42 PM »
New question!
My backup camera was destroyed in the accident. I wasn't going to replace it because I didn't feel like running the wires and shit all over. BUT when I was fixing my system I noticed these wires were taped up on the inside of the headliner in my trunk. My question is, if I get a new camera, can I just plug it into these wires and be good to go? The two wires that are electrical taped up had a yellow tag with writing on it. I noted in the picture what the writing said on each wire.
A lot of the rear view cameras I looked up seem to have different connections so I'm not sure what to do. For example:
Reply #457 on:
September 21, 2012, 02:23:59 PM »
You should be able to used the old harness if you get the same type of rearview cam you already had
Reply #458 on:
September 21, 2012, 03:28:24 PM »
The thing is, the camera came with the POS chinese HU I have. No clue where to get a new one, the company isn't even around anymore.
Reply #459 on:
September 21, 2012, 03:37:43 PM »
I'm not surprised the company isn't around anymore. Was the old camera the type that goes above the plate or was it a license plate light replacement type?
Reply #460 on:
September 21, 2012, 11:53:19 PM »
Back up cameras should all have the same signal wires. You should have power and ground and then 2 wires for the video signal.
Reply #461 on:
September 22, 2012, 03:58:41 PM »
Ordered a PDX5, baffles... b-queit came in already
Need ot find me a backup camera though!
Reply #462 on:
September 23, 2012, 09:19:51 AM »
I have one in my trunk keyhole. I just got an inexpensive one off of eBay. Where in Ontario are you again?
Reply #463 on:
September 24, 2012, 09:08:14 AM »
Quote from: CrackerTeg on September 21, 2012, 03:37:43 PM
Above the plate type.
Reply #464 on:
September 25, 2012, 10:02:05 AM »
I am in Oakville (Toronto Area)
30
31
32
33
43
