August 21, 2026, 05:15:39 AM
Wheels & Tires
**Wheel Recommendations/Consideration Thread**
11
20
Topic: **Wheel Recommendations/Consideration Thread** (Read 217506 times)
Re: **Wheel Recommendations/Consideration Thread**
Reply #120 on:
January 21, 2010, 10:46:51 AM »
I skimmed over the fact that you had a coupe. If I were you, I would go with 18x8.5 +48 in the front and 18x8.5 +35 in the rear with 255/40/18.
Silver Bullet
Reply #121 on:
January 21, 2010, 04:04:15 PM »
Quote from: "alpha"
Quote from: "Silver Bullet"
I don't have any fender mods done but if necessary, I will. No cambers yet, I'm just planning ahead.
Would it be possible to run 235/40/18 on the 18x7.5 wheel? Maybe the wider tire might help it seem more flush? And how badly would it throw the speedo off?
For reference, my car is a coupe. Stock tires = 205/60/16.
If I can run 235 on the 18x7.5 then I would eliminate the 18x8.5 as my option then.
Thanks for your help =)
You can run 235 on a 18x7.5 wheel, yes.
Here is a helpful link to calculate how much your speedo will be off:
http://www.miata.net/garage/tirecalc.html
So it sounds like you want something wider without going extreme. 18x7.5 +43 looks to be your option. If it doesn't sit as flush as you want with the fender, you could always consider spacers.
Alpha, I did look up the tire calculator and running 235 vs 225, is only 1.1 % diameter difference. Only thing is, the recommended wheel width for 235 is 8in - 9.5 in.
I am running 215/55/16 on my stock wheels that came with 205/60/16 tires. Only thing is, the lip on the wheel seems "sunk" in now, so would running those 235's on the 18x7.5 yield the same result?
2006 AV6 6MT
Silver Bullet
Reply #122 on:
January 21, 2010, 04:09:35 PM »
FWIW, I'd get the 18x8.5 +48 with 255 or 265's. If they're not flush, I'd run spacers. I didn't do the math to see what would be closest to your stock tire size so your speedo would't be thrown off, so take that into consideration.
I looked and the only size where my speedo isn't thrown off at all is 245/45/17 for the 17's. I'm tempted to get the 17's but then again I haven't seen enough 7th gen's running aftermarket 17's. The majority run 18's so idk =/
Thanks for your input Tim.
2006 AV6 6MT
Silver Bullet
Reply #123 on:
January 21, 2010, 04:12:21 PM »
Quote from: "alpha"
Alpha, I'm not looking to do a staggered set up. I rather still want to be able to rotate my tires. I bet it would look good tho on the coupe. My brother who has a 8th gen coupe wants to go with a set up similar. Thanks!
2006 AV6 6MT
Reply #124 on:
January 21, 2010, 05:13:29 PM »
sup silver
i just got 225/45/18's on my 18x7.5 and they are basically identical width, so 235 i think would easily work on 7.5 and just be a tiny bit wider than the wheel
Since with you have a coupe
i'd take the 18x8.5 and go 245 or 255 with an offset of +35
Reply #125 on:
January 21, 2010, 06:30:09 PM »
The funny thing with tires is that the same width can be different sizes when going across brands. So, a 235/45/17 Bridgestone can be wider than a 235/45/17 Michelin. Each tire is made differently, some are narrower and some are wider in the same respective size.
There is a chance that 235 on a 7.5" wheel will yield the same result, yes. It all depends on the tire choice.
There are plenty of people running aftermarket 17s on the Accord. A lot of the people on this forum run 17s from another Honda product, i.e. TL wheels and TL-S wheels that are 17x8 +45.
Ok, in that case, I would recommend the same as Tim's recommendation. 18x8.5 +48 with 255/40/18. If you want to make the rear more flush, get spacers.
Hope this helps.
Silver Bullet
Reply #126 on:
January 21, 2010, 06:33:24 PM »
I'm thinking about it. Only thing stopping me is that the 18x8.5 weights 22 lbs (5lbs more than 18x7.5) and it cost more so I might jus do what tim said and get spacers.
2006 AV6 6MT
Silver Bullet
Reply #127 on:
January 21, 2010, 06:38:29 PM »
I'll wait and decide after the springs settle. Thanks for the help guys! =]
2006 AV6 6MT
Reply #128 on:
January 21, 2010, 10:34:22 PM »
FWIW, I have 245/40/18 on my 18"x7.5" +42 mm wheels. You can run wider tires if you want to. If it were me, I would get the widest wheels that I could fit under my car. Of course, I have a little more power than most people, so grip is an issue.
Reply #129 on:
January 24, 2010, 07:26:09 PM »
sortof related to wheels:
does anyone know of tuner lug (cone seat) lugs that have irregular locks, that come in red?
What I mean is, locks that aren't just the same in every pack of the same type (I think Rays/Works are like that ? correct me if I am wrong). So I am looking for locks that are like Mcgard but red
lilfotoman
Reply #130 on:
January 25, 2010, 02:11:12 AM »
JT you make a thread like this lol
Reply #131 on:
February 04, 2010, 08:59:59 AM »
Quote from: "lilfotoman"
Haha you know it Tim!
Reply #132 on:
March 01, 2010, 11:57:34 AM »
so im looking at a set of 17x7 +43 and didnt know what the best size tire would be. i want to stay close to my oem rolling diameter which the stock tires are 205/60-16. any info would be appreciated.
Reply #133 on:
March 01, 2010, 12:56:50 PM »
Maybe you didn't notice this thread David. Check it out first.
Wheel Offset and Tire Size Calculator
Reply #134 on:
March 01, 2010, 01:22:01 PM »
thanks tim, i saw the thread but the calculator wasnt working for me so i wanted to ask here were i trust the answers of those giving it to me.
11
20
