September 27, 2026, 07:37:42 AM
[PROFILE] Nit3h4wk C0up3
41
42
43
44
55
Topic: [PROFILE] Nit3h4wk C0up3 (Read 430212 times)
Re: [PROFILE] Nit3h4wk C0up3
Reply #615 on:
May 30, 2013, 09:17:15 PM »
Denny, passenger side drain tube is in the front and the drivers side is towards the rear.
http://www.driveaccord.net/forums/attachment.php?s=617b12bf279fe5ae26d9f215f0902df0&attachmentid=19199&d=1237836405
See here
Re: Re: [PROFILE] Nit3h4wk C0up3
Reply #616 on:
May 30, 2013, 10:02:38 PM »
I found the driver's side tube, and I blew some air through it, then poured some water. It came out right behind my wheel, hopefully I unclogged the clog. I'll find out the next time it rains...
Thanks for the link i'm going to check it out now...
Also, I was really amazed at how easily the interior pillar came off...
Reply #617 on:
May 30, 2013, 10:21:54 PM »
I had no idea the sunroof had drain tubes. This might be why my sunroof drips occasionally. I'm going to have to try this as well...
Reply #618 on:
May 31, 2013, 08:00:02 AM »
Quote from: Nit3h4wk C0uP3 on May 30, 2013, 10:02:38 PM
You could always get Rob to sit inside the car and then you run the hose over your roof.
Reply #619 on:
May 31, 2013, 01:56:17 PM »
^^ That's a win win. Either you prove the clog is gone or he gets soaked.
Reply #620 on:
June 23, 2013, 12:10:56 AM »
Great meeting both you and rob today!!
Reply #621 on:
June 23, 2013, 12:29:06 AM »
Likewise! Was nice to meet you too
Reply #622 on:
July 05, 2013, 06:47:22 PM »
The body shop is a scary place. ^^ this is just to fix my front end. Granted it's before the discount but still......
Reply #623 on:
July 05, 2013, 10:14:49 PM »
Ouch, that's a lot. What work is the quote for?
Reply #624 on:
July 05, 2013, 10:24:06 PM »
To figure out why everything is misaligned, and to have everything repainted. One fender is just a lost cause, and the other might be covered by Honda because of all the cracks in it. But they're not sure exactly what the issue is until they take it apart..
Reply #625 on:
July 26, 2013, 07:34:18 AM »
Ok, this is getting a bit frustrating. Nov 2012 I bought a foglight kit (2d) from Amazon. I didn't open the box. My bad I know! Last weekend I finally got around to having someone help me install them. I talked to the AFH parts dept and the kit is discontinued, but some parts are available. Not the bracket. I emailed the seller and I got the "oh well it's past 90 days too bad" answer. Does anyone know where I might be able to get this bracket(s) without buying a whole new kit? I'm not sure if I should be mad at myself or not...probably..
Re: Re: Re: Re: [PROFILE] Nit3h4wk C0up3
Reply #626 on:
July 27, 2013, 08:29:58 AM »
Quote from: Nit3h4wk C0uP3 on July 26, 2013, 07:34:18 AM
Buy new kit on amazon if available then return kit with missing parts.
Reply #627 on:
July 27, 2013, 10:43:26 AM »
Quote from: Mike on July 27, 2013, 08:29:58 AM
Reply #628 on:
July 27, 2013, 03:08:30 PM »
But that's lying! I can't do it
Headlight update, here's a progress pic
Reply #629 on:
July 28, 2013, 12:25:32 AM »
I want to replace my fogs soon, only need the lens tho. Wanna go half when I'm ready?
41
42
43
44
55
