October 25, 2026, 08:57:34 PM
Author Topic: Door Switch not working  (Read 35096 times)
« Reply #30 on: February 27, 2012, 10:59:06 PM »
Hahaha.  Good luck when the rain clears up.
mnkyman
mnkyman pfffft.
« Reply #31 on: February 28, 2012, 09:54:11 PM »
Tried switching the switch with a new one and no luck Sad
Sam -|- 2006 I4 Sedan SE
« Reply #32 on: February 28, 2012, 10:00:00 PM »
Fuck dude.  That sucks.  Lemme spend a little time doing some reading tonight.
mnkyman
mnkyman pfffft.
« Reply #33 on: February 28, 2012, 11:11:54 PM »
Ya, I was half expecting that since I couldn't find anything special about the switch, but was still crossing my fingers. Thanks man, I appreciate it!
« Reply #34 on: February 28, 2012, 11:54:36 PM »
Okay.  First, the light shouldn't have anything to do with this problem.  It will not affect how your door switch works.  I've been reading through a few things and here's what I'd suggest you do.  If you have a digital multi meter, take it out and follow these steps:
remove the left kick panel to get access to the cabin fuse/relay box
remove the 14 pin connector from the fuse relay box
check for damage to the connector and wires
check the light green/red wire in cavity 12 on the connector for damage (that's the wire for the passenger door switch)
reconnect the 14 pin connector
test again, and if it doesn't work continue on
with the door open check for voltage to ground on the light green/red wire
if you don't get 1v or less, it's either the switch or a damaged wire
That's about it Sam.
mnkyman
mnkyman pfffft.
« Reply #35 on: February 29, 2012, 12:40:38 AM »
Thanks Tim! I'll check out the connector sometime this week, hopefully that fixes it. If not, I'll be back in Houston in ~2 weeks, where I left my multimeter and will be able to check out the problem further.
« Reply #36 on: February 29, 2012, 08:27:31 AM »
Good luck with that man.  Hit me up if you need help while you're checking through things.  You have my number, right?
mnkyman
mnkyman pfffft.
« Reply #37 on: February 29, 2012, 11:02:48 AM »
Naw, I think I lost it when I switched over phones. Sent you PM!
