September 20, 2026, 11:01:04 AM
Author Topic: How To: Lightweight Crank Pulley  (Read 19810 times)
« on: February 12, 2012, 11:11:25 PM »
Here is a DIY on how to install a crank pulley on our Accords. I used my buddy's TL for this, but its the same configuration as our Accords. Now lets begin.
Tools:
14mm wrench or a serptine belt tool.
19mm deep impact socket
breaker bar (a fairly long one)
flat head screwdriver or honda clip puller tool
floor jack
jack stand
Step 1: Make sure your car is in park (automatic) or neutral (manual) with the e-brake applied. Open hood and locate your belt tensioner.
Step 2: Using a 14mm wrench or a serpentine belt tool, push the wrench or tool towards the back of the car to relieve tension from the belt. (if the 14mm wrench is too short, add another wrench preferably bigger to add leverage) Remove the belt aside unless you are adding an underdrive, then you will need to replace the belt. (if replacing the belt, remember the belt routing diagram)
Step 3: Proceed to jack up the right side and apply a jack stand to remove the wheel. Remove the wheel.
Step 4: Locate the 2 clips holding the crank pulley cover. The second clip is behind the frame. If you were to look from the bottem, you would see it. Remove both clips and move aside.
Step 5: Locate the crank pulley bolt. Using a breaker bar and 19mm impact socket, place the socket and breaker bar on bolt and wedge between the control arm and tie rod.
Step 6: (Do Not Freak Out On This Step) Get inside your car and bump your key over. You will be using the starter to break loose the bolt. This may take a few tries to get the bolt loose. (do not try to start your car but just giving it a couple of bumps so that starter partially turns over). After you have gotten the bolt loose, remove the bolt and pulley.
Step 7: Install the pulley on. Make sure you line up the notch on the pulley to the notch on motor.
Step 8: Hand start the bolt and then bolt it down. Place your belt back on and put everything back on. You have successfully installed your crank pulley.
« Last Edit: February 21, 2012, 12:34:34 AM by MyNameIsThien » Logged
Arielit0oo pfffft.
« Reply #1 on: February 12, 2012, 11:33:31 PM »
Nice write up Thien.
« Reply #2 on: February 21, 2012, 12:35:32 AM »
Video added for reference on how to use the breaker bar and using the starter to break loose the crank pulley bolt.
« Reply #3 on: February 22, 2012, 01:41:09 AM »
Great write up will be trying this soon
« Reply #4 on: March 13, 2012, 01:33:32 AM »
Don't forget to pull the fuel pump fuse. Or else it will crank over.
theycallme_og
not that kind of OG
theycallme_og pfffft.
« Reply #5 on: January 03, 2013, 02:53:14 PM »
 Huh? THIS IS HOW ITS DONE Huh?
I have had a pulley sitting for nearly two years, because I was too scared to try installing it on my own...  mad
Well thanks for the write up, I am going to install mine this weekend.  Grin
« Last Edit: January 03, 2013, 05:07:22 PM by theycallme_og » Logged
« Reply #6 on: January 03, 2013, 11:33:06 PM »
Added note. It is best to have a fully charged battery. If you have a fairly weak battery, it won't work.
accordguy04 pfffft.
« Reply #7 on: January 04, 2013, 12:00:13 AM »
I miss my crank pulley... Sad
Took it off cause of a vibration, ended up being two broken axles.   Lol
Def made a nice diff tho, the engine just ran smoother gear to gear.
Milan pfffft.
« Reply #8 on: January 04, 2013, 12:16:59 PM »
What is the torque spec for putting the bolt back on the pulley?
« Reply #9 on: January 04, 2013, 12:58:06 PM »
German. Duh.
theycallme_og
not that kind of OG
« Reply #10 on: January 04, 2013, 09:31:27 PM »
And the pulley is on my car  Grin
Thanks again for this write up
accordguy04 pfffft.
« Reply #11 on: January 04, 2013, 10:21:39 PM »
German. Duh.
I'm lost...?
« Reply #12 on: January 04, 2013, 10:22:58 PM »
Gudenteit.
fatbastard
fatbastard pfffft.
« Reply #13 on: February 03, 2013, 08:33:24 AM »
to those with lightweight pulleys installed -- any issues so far?
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
olecram39
olecram39 pfffft.
« Reply #14 on: October 29, 2013, 05:33:40 PM »
I used this write up to install my light weight pulleys. Thank you OP.
And to the previous poster, I've had them since around July and no problems so far.
