May 01, 2026, 04:51:51 AM
Author Topic: Question about different banjo bolts for Goodridge SS lines  (Read 4498 times)
quickkick127
quickkick127 pfffft.
« on: December 18, 2011, 11:57:06 AM »
Hey guys, I bought a set of goodridge ss brake lines off another member recently and threw them on thursday which cost me a new rear caliper since the bleeder just snapped right off.  Well after getting a new one and getting it painted, I tried to throw it on last night and this time the bolt that goes through the banjo snapped before it even felt like it was seating.  This bolt was supplied with the ss lines.  I had my buddy go dumpster diving to find the original bolts (since we did the initial job at his house) but there are a few differences.  The original bolt only has one inlet hole while the Goodridge ones have two.  The original bolt is longer even though the ss banjo is wider than the factory one.  Also the hollow shaft of the goodridge bolt is of larger diameter.  It would seem that the goodridge bolt will allow for more flow than the factory bolt.  Do you think I'll have an issue with running the factory bolt?  I'd actually rather use the factory bolts cause the Goodridge bolts are so light and cheap feeling in comparison.  Thanks for your opinions.
Rushzer0 pfffft.
« Reply #1 on: December 18, 2011, 12:48:32 PM »
You should not have any issue running the original banjo bolt, they just tried to improve on the design of the bolt, as long as it doesn't leak your golden.
« Reply #2 on: December 18, 2011, 08:58:20 PM »
New bolt was probably meant to allow increased flow with a sacrifice made in fit.
