November 06, 2026, 09:56:41 PM
Brakes
Once again i need to diagnose my brakes
Topic: Once again i need to diagnose my brakes (Read 21914 times)
May 20, 2011, 12:45:02 AM »
So last year i replaced my rear passenger side caliper because it kept sticking on me. I had a feeling it wasnt the issue
My issue is that my one caliper sticks and over heats. Causing premature wear and rust. But everytime my mechanics checked it moved freely. I replaced it anyways. Everything was fine for the first six months. I can tell when my brakes are acting up because i hear a zooming noise (vibration) from that one caliper and i get some brake fade... I dont know what to do. Its basically the only problem ive had with this car. I hate using my brakes cause it feels rough and sounds awful (mind you my discs are slotted, but when operating normally they are quite) Also that one disk will not scrap clean. But i checked the caliper and it moves freely
Last Edit: May 20, 2011, 12:51:12 AM by fabulous010
Re: Once again i need to diagnose my brakes
May 20, 2011, 07:01:12 AM »
Did you replace just the caliper, or did you replace the caliper bracket and guide pins too?
May 20, 2011, 03:49:36 PM »
I recently had to replace a 2yr old caliper because I didnt replace the mount and guide pins. You definitely want to replace everything and make sure the rubber section of the line going to that wheel is in good shape I.e. not soft because this may cause it to kink and not release. GL.
May 20, 2011, 03:56:18 PM »
The other thing is to make sure the guide pins move freely and are well lubricated.
May 21, 2011, 10:16:39 AM »
I replaced the whole thing bracket and all.
May 21, 2011, 03:06:06 PM »
Try replacing that rubber section of the line. I believe it's around $20.
May 22, 2011, 12:28:18 PM »
Have you flushed your brake fluid? The shop said the current caliper on your car was good, right?
May 23, 2011, 11:18:41 PM »
Ya it was fine after he greased the Pins again. I believe something is causing the caliper to malfunction. But all the other calipers work fine with minimal maitanence. This one caliper requires special attention even after replacing with a whole new one
InFuMoUs
May 24, 2011, 11:52:34 AM »
Maybe something is wrong with the brake line to that caliper. Do you know if brake fluid is flowing freely when it isn't connected to the caliper?
Steve -
Squad/
Team Crazy Creashunz
May 24, 2011, 01:24:49 PM »
Where did you buy the caliper. I could be a Reman that didn't go so well I see these things come back into my store all the time.
May 24, 2011, 08:09:20 PM »
Quote from: InFuMoUs on May 24, 2011, 11:52:34 AM
Thats what im thinking. Mechanics check the caliper and say its fine. I think some where down the line fluid isnt going through the lines to that caliper. I wasnt sure if a faulty master cylinder would do that. Woulndt a faulty master cylinder cause no pressure in all the brakes? Same thing with bad fluid, that it would affect all brakes?
How can i diagnose the line going to that brake? Also i noticed how clean that one rims stays, and how dirty caliper is
InFuMoUs
May 25, 2011, 11:20:46 AM »
I think if it was the master cylinder, it would affect all and not just one but I could be wrong about that. See if you can diconnect the brake line from the caliper and have someone press the brake and watch the flow of the fluid. You can follow the brake line under the car to the abs modulator. They're all close to each other underneath the car you can't miss it. Hopefully one of em isn't bent.
Steve -
Squad/
May 25, 2011, 12:20:35 PM »
there is also a proportioning valve.
InFuMoUs
May 25, 2011, 02:05:59 PM »
Doh
forgot about that. Well I guess we just gotta wait and see by process of elimination.
Steve -
Squad/
fatbastard
June 05, 2011, 03:35:55 AM »
can a bad brake line cause caliper stuck-up?
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
