August 15, 2026, 10:10:05 PM
Stuck spark plug (solved)
Topic: Stuck spark plug (solved) (Read 22586 times)
Re: Stuck spark plug
March 08, 2011, 09:44:03 PM »
about as long as pencil. but there's different holders for them. That's about the only thing I can think of.
GNskates
March 08, 2011, 09:49:33 PM »
I guess Ill go looking around a bit more for tools thatll be usefull for this.
March 08, 2011, 09:56:18 PM »
Hmmm, what if you get a dry/wet vac, get an attachment that will go over the hole, then try to suck the damn thing out? Just make sure you clean out the vac's tub before you do this, so you can find the thing again.
Not sure if it'll work, but hey, you've tried everything else, so what the hell!
March 08, 2011, 09:58:36 PM »
I was actually thinking about that idea too. But I figured, if he already tried pulling it out with pliers and it didn't move, then a vacuum cleaner won't be able to help either.
March 08, 2011, 11:07:25 PM »
You may want to try locking forceps (kelly clamp). It's long and thin enough to reach in there to get it, and the locking mechanism makes it easier to get a good grip.
GNskates
March 08, 2011, 11:11:41 PM »
Dont forget this rubber is hard as fuck. I was thinking of finding a long ass 15" radiator hook pick.
March 08, 2011, 11:12:56 PM »
Sure. I was just throwing out an idea. So, is this the rubber that's usually on the inside of the spark plug socket that's stuck in there?
GNskates
March 08, 2011, 11:17:51 PM »
Correct
Reply #23 on:
March 08, 2011, 11:23:30 PM »
Bummer. Does the socket have a warranty. You could have them recoup the expenses to have a mechanic get it out.
GNskates
Reply #24 on:
March 08, 2011, 11:37:37 PM »
I had these tools for a while. And i dont have a warranty.
Reply #25 on:
March 09, 2011, 08:25:23 AM »
I would be slightly afraid that it might melt during an extended trip... Just a thought that was in my head and I figured I would share.
Reply #26 on:
March 09, 2011, 01:03:57 PM »
It kinda looks like it did already.
GNskates
Reply #27 on:
March 09, 2011, 09:46:14 PM »
well good news guys, i finally got it out with in a hour with a small knife and knitting needles
what i used to suck out the chunks of rubber was straws duct taped around the vacuum. took time, but i finally got it all out. thank you guys for the tips.
Re: Stuck spark plug (solved)
Reply #28 on:
March 09, 2011, 10:28:01 PM »
Glad you got this cleaned up man.
Reply #29 on:
March 09, 2011, 10:36:58 PM »
awesome
