April 04, 2026, 08:06:58 AM
K24a4 injector flow rate?
Topic: K24a4 injector flow rate? (Read 26411 times)
fatbastard
Re: K24a4 injector flow rate?
January 11, 2011, 07:59:23 AM »
Quote from: timot_one on December 24, 2010, 10:50:10 PM
Acura RDX injectors are 410cc. They are a better upgrade over stock.
forgot to ask if these fit without any modifications like spacers, wiring sockets and clips?
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
January 11, 2011, 08:31:00 AM »
They fit just fine. The only thing you have to do is re-wire the injector clips with the ones that come with the ones from Hybrid Racing. That's thread may help you understand what's involved.
DIY: RDC 410cc Injector Upgrade
We do have a K Series Engine Performance Forum. It may help to browse through that section. A lot of your questions can be answered there with a little bit of research.
Last Edit: January 11, 2011, 08:33:17 AM by timot_one
fatbastard
January 11, 2011, 08:45:06 AM »
im not sure if i really need an injector upgrade. do i wait for the stock ones to max out first before buying them?
up to how much power do the 270cc injectors support anyway?
-- Charles --
January 11, 2011, 09:05:54 AM »
Around 180-200 hp. A very simple upgrade would be to get a set of RSX-S or TSX 310cc injectors. Those will support up to 250 whp.
fatbastard
January 11, 2011, 09:39:15 AM »
do i also need to swap sockets and clips with the TSX injectors?
-- Charles --
January 11, 2011, 10:22:47 PM »
I'm 99.9% sure they are the same. I'll have to double check later after I move. I have a few sets of Accord and TSX injectors, and an Accord and TSX engine harness. The problem is that I've already packed them away since I'm about to move to a new state.
fatbastard
January 11, 2011, 11:14:46 PM »
Tim you're such a big help!
in the meantime i'm waiting for my parts to ship out from the US. i have just received an email yesterday that the skunk2 stage1 cams were on backorder for about 30-45 days, so i opted for the stage2. also had a sudden order of dual valvesprings and titanium retainers with those. whew!!
-- Charles --
January 11, 2011, 11:25:54 PM »
I hope the stage 2's work out for you man. Swapping the valvesprings and retainers is a must for those cams.
fatbastard
Reply #23 on:
January 11, 2011, 11:30:30 PM »
yeah getting excited over this whole engine mod mania. the cams are set to arrive with the intake, headers, and some other bits and pieces.
do you know where i can get those stock tsx injectors cheap? im using a credit card.
-- Charles --
Reply #24 on:
January 12, 2011, 12:00:25 AM »
Try Acura. What header did you get?
fatbastard
Reply #25 on:
January 12, 2011, 12:05:52 AM »
the DC ceramic. crappy choice?
i already have a flexpipe waiting just in case.
-- Charles --
Reply #26 on:
January 12, 2011, 12:10:44 AM »
Well, it's an inexpensive header. It is a decent bolt on, but a more expensive race header is appropriate for a built motor.
fatbastard
Reply #27 on:
January 12, 2011, 12:13:06 AM »
i'll consider the SSR header if my motor pumps out decent gains with what i'll be installing. looking at a final tune of 200hp.
-- Charles --
