April 04, 2026, 04:10:56 AM
Author Topic: K24a4 injector flow rate?  (Read 26395 times)
fatbastard
fatbastard pfffft.
« on: December 24, 2010, 02:34:34 AM »
does anyone know the flow rate of the stock fuel injectors of the K24a4?
i wanna know how much extra power i can add/make using the stock injectors.
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
« Reply #1 on: December 24, 2010, 08:52:04 AM »
They are 270cc injectors.  You will be fine with basic bolt ons using the 270cc injectors.  Even with the "stage 1" SC kits that Comptech sells for the RSX/TSX, you can continue using the 310cc injectors that come with them.  What exactly were you planning on doing?  What engine management are you running?
fatbastard
fatbastard pfffft.
« Reply #2 on: December 24, 2010, 08:19:38 PM »
i have just ordered the AEM short ram intake, dc ceramic headers, and skunk2 stage1 cams, and i'll be running e-manage ultimate.
any chance i'll be maxxing out the injector duty cycle with these mods??
-- Charles --
« Reply #3 on: December 24, 2010, 09:24:04 PM »
You may come close, but why e-manage ultimate?
fatbastard
fatbastard pfffft.
« Reply #4 on: December 24, 2010, 09:57:18 PM »
because of the unavailability of a TSX ECU for Hondata. parts are hard to come by around here. in fact im having the parts shipped in from CA. difficult to buy from non-store entities....  Sad
-- Charles --
« Reply #5 on: December 24, 2010, 10:21:31 PM »
You can't kpro a TSX ECU.  You will need to get either a PRB (RSX Type S), PND (Base RSX), PRC (Integra Type R), PNF (Civic Si), PRD (JDM Civic Type R), or PRA (EDM Civic Type R).  You are better off contacting Hondata and getting a kpro ECU from them directly.
You probably want to do some research first before you start wasting money on parts you can't use.
fatbastard
fatbastard pfffft.
« Reply #6 on: December 24, 2010, 10:37:29 PM »
you got it right on that one.
wonder why hondata won't make it easier for all of us right from the start...  :Smiley
-- Charles --
« Reply #7 on: December 24, 2010, 10:42:51 PM »
There is not a lot of interest in modifying Accords when you compare it to Civics, Integras and RSXs.  There is really no benefit for them to develop a product for it.  There are also a lot of hurdles with the Accord ECU since it cannot be modified.  The only option is a dual ECU.  They just didn't seem to get it right for some reason, and there were reliability issues with that set up.  That's why they stopped making the dual ECU harness for the TSX.  Fortunately, k-tuned picked up the slack and made a dual ECU harness for the TSX.
fatbastard
fatbastard pfffft.
« Reply #8 on: December 24, 2010, 10:46:25 PM »
are Deatschwerks 450cc injectors a good upgrade from stock?
wanting to be prepared if i need to replace the stock ones.
-- Charles --
« Reply #9 on: December 24, 2010, 10:50:10 PM »
Acura RDX injectors are 410cc.  They are a better upgrade over stock.  They have OEM reliability and have a better spray pattern than aftermarket.  They are also less expensive.
fatbastard
fatbastard pfffft.
« Reply #10 on: December 24, 2010, 11:01:49 PM »
yeah you're spot on!
found a set for $195 + shipping. thanks!
www.hybrid-racing.com
-- Charles --
« Reply #11 on: December 25, 2010, 09:20:13 AM »
That's why we're here.  I may not know everything, but I know a little bit about what you're trying to do.  That's why we have a community like this though.  Among all the members here, there's a good amount of information in here to help other people.
tennis
tennis pfffft.
« Reply #12 on: January 09, 2011, 09:49:42 PM »
hey tell me how the skunk2 stage 1 cams fit
« Reply #13 on: January 09, 2011, 11:16:43 PM »
What does that have to do with OEM injector flow rates?  The Skunk2 camshafts should fit just fine.  What kind of question is that anyway?
tennis
tennis pfffft.
« Reply #14 on: January 09, 2011, 11:40:01 PM »
cause i had some issue's when i did it and i think it might have been the installer... just wanted to see how his turned out
