September 30, 2026, 08:33:57 PM
Engine Mounts
Topic: Engine Mounts (Read 39495 times)
Engine Mounts
December 11, 2010, 01:29:32 PM »
How do you know when they need to be replaced? I'm getting this vibration sometimes when I'm pulling out in 1st gear. I suspect that this might be the issue. But then again, I don't know much.
Re: Engine Mounts
December 11, 2010, 07:39:45 PM »
Excessive movement, tears, leaking oil from the dampeners, etc. From the symptoms I described, the only way to know is to visually inspect them. Vibrations when accelerating from first is a pretty good indicator something is amiss.
Re: Engine Mounts
December 11, 2010, 09:01:15 PM »
I think I'm fucked. Great! God knows how much this is gonna run me now.
Re: Engine Mounts
December 11, 2010, 10:12:01 PM »
Ask Mike. He had to replace a couple mounts he didn't even know were bad. I think Arie just did too. Shop around for prices on parts and do that shit yoself son!
Re: Engine Mounts
December 11, 2010, 10:27:54 PM »
I sent Arie a text earlier. I'm pretty sure he did too. He's probably buried in his books, studying.
Re: Engine Mounts
December 11, 2010, 10:51:39 PM »
Is that what he's calling it? I gotta catch up on the slang.
Re: Engine Mounts
December 11, 2010, 10:59:53 PM »
Talk to NVA-AV6 he can refill them for you, and they will be good as new. He might even have a set he can send you, and you can send yours back his way (sort of like a core) It will preform as well or better than new, and be boat loads less. I had two mounts gone and didn't have an idea...
Re: Engine Mounts
December 11, 2010, 11:01:43 PM »
I had one of my bad mounts replaced $287, and NVA fixed one, and I think it was $60 just to give you an idea. Please don't take that $60 as a fact though because he may charge more, and I don't remember what was what because I had him do other work at the time.
Re: Engine Mounts
December 11, 2010, 11:12:25 PM »
Thanks Mike. As good as Paul is, I don't think I'm going to be driving to VA for this. Maybe for something, but I don't know if I will for this. I appreciate the suggestion though and I'll PM him. I'll also ask my local shop how much they'll charge.
Last Edit: December 11, 2010, 11:17:58 PM by gargantula99
Re: Engine Mounts
December 11, 2010, 11:24:58 PM »
Have them install the ones you get from Paul and you will still save money. Which one is broken? One or two of them are very easy to change
Re: Engine Mounts
December 11, 2010, 11:30:52 PM »
I'm not sure. I'll check tomorrow. I'm assuming that's what it is since practically everything shakes in the front end of the car, dashboard, steering wheel.
Re: Engine Mounts
December 12, 2010, 12:57:22 AM »
I dont know generally broken mounts would make you feel less vibration
Re: Engine Mounts
December 12, 2010, 01:26:48 AM »
Not in a FWD during acceleration. His mounts may be so far gone that whenever the engine rocks, he feels it.
Re: Engine Mounts
December 12, 2010, 01:26:52 PM »
From personal experience when mine were fixed I felt 1,000,000 times more vibration. Mine were broken completely in half so it was like the engine was sort of just floating around.
Re: Engine Mounts
December 12, 2010, 05:11:25 PM »
Its possible you got used to the floating engine rather than what your car was supposed to feel like?
