July 26, 2026, 04:22:10 AM
Author Topic: Comptech SC from TSX fits 7G?  (Read 39161 times)
fatbastard
fatbastard pfffft.
« on: November 11, 2010, 07:45:52 PM »
so i've decided to start modding the K24a4 for a 200whp target.
first thing that comes to mind is the Comptech (now CT Engineering) SC kit for the TSX. will this bolt right in? i gotta be dead sure as i'll be shipping this in from USA and a return or exchange is not really an option.
i'll also be using the e-manage ultimate for a piggyback. any bad reviews regarding this one?
i decided against KPro because i can't get TSX ECUs in my country  Embarrassed
any help would be appreciated.
« Last Edit: November 11, 2010, 07:51:01 PM by fatbastard » Logged
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
« Reply #1 on: November 12, 2010, 02:00:24 AM »
Yes it will. For the most part, everything engine related from the TSX will bolt on. As for the e-manage, there's mixed reviews floating around the internet. Why can't you get ahold of a TSX ECU if you can get ahold of the CTSC? You're better off with kpro anyway as it controls all engine parameters and will net you a better performing engine.
fatbastard
fatbastard pfffft.
« Reply #2 on: November 12, 2010, 03:21:03 AM »
the CTSC is easier to get hold of as i order it straight out of CT's website and i pay via credit card.
not easy to get hold of the TSX ECU as there's no online store which sells them, and i had enough of eBay!
-- Charles --
« Reply #3 on: November 12, 2010, 04:33:45 AM »
Have you tried looking in this thread for online dealers that may be able to help you out?
For the record, there's no way in hell I was going to suggest egay.
neoryan7
neoryan7 pfffft.
« Reply #4 on: November 13, 2010, 04:50:40 AM »
If I remember correctly you might have a problem with the idle air control valve. A notch needs to be cut in the mounting flange for the TB. I saw that the mounting flange in the installation guide looks like an 06+ intake manifold (TSX or ACCORD) instead of looking like an 03-05.
fatbastard
fatbastard pfffft.
« Reply #5 on: November 14, 2010, 09:41:09 PM »
my mechanic can take care of all minor metal works which need to be sorted out.
my concern is if im gonna hit a major roadblock with parts fitment and adaptability.
also gotta do some research re: fuel injectors which will bolt on.
-- Charles --
fatbastard
fatbastard pfffft.
« Reply #6 on: December 24, 2010, 09:00:32 PM »
do you have the file of the installation manual?
im still doing further research on this viability of this one. in the meantime, i have the intake, headers, cams, and ems coming soon. Smiley
-- Charles --
« Reply #7 on: December 24, 2010, 10:12:28 PM »
Ryan is correct.  Machining the SC inlet would be necessary for the IACV since the TSX doesn't have an IACV.  You could also use the RSX Type S inlet with a RSX Type S TB instead.  N/A cams will hurt your performance if you're planning on getting the SC.  You can make 200 whp with the SC alone.
Greddy e-manage is a bad idea.  I haven't heard anything good about it.  You will make more power reliably using kpro.  Try contacting a Hondata dealer or Hondata directly to get kpro.  You don't need a TSX ECU to run kpro, but you will need a dual ECU harness to use a kpro ECU.  You can contact Cham to get a harness.
What country are you in?
fatbastard
fatbastard pfffft.
« Reply #8 on: December 24, 2010, 10:33:25 PM »
will see what happens then, i'll take it one step at a time.
the boomslang harness will arrive anytime soon. too late to switch options i guess.
im based in manila, philippines.  Smiley
-- Charles --
« Reply #9 on: December 24, 2010, 10:36:29 PM »
You'll end up spending less money doing it right the first time around.
fatbastard
fatbastard pfffft.
« Reply #10 on: December 24, 2010, 10:38:55 PM »
will research on Hondata then.
re: TSX supercharger, should i be looking at the '04 A/T engine or something else?
-- Charles --
« Reply #11 on: December 24, 2010, 10:40:56 PM »
It should all be the same.  Do you have an AT or a MT?
fatbastard
fatbastard pfffft.
« Reply #12 on: December 24, 2010, 10:43:18 PM »
5AT.
-- Charles --
« Reply #13 on: December 24, 2010, 10:46:18 PM »
Either kit will work.  I'm not sure why they have a different kit for one or the other.  There may be some small parts that are different.
fatbastard
fatbastard pfffft.
« Reply #14 on: December 24, 2010, 10:48:24 PM »
yeah i reckon, emailed CT Engineering and they gave me a general answer saying that the SC will fit, but some small parts may need to be modified.  :Smiley
-- Charles --
