August 09, 2026, 07:55:30 PM
Author Topic: How To: Ultra Racing 4 Point Rear Lower Arm Brace  (Read 28418 times)
« on: October 28, 2010, 07:18:49 PM »
Here is a DIY and review on the Ultra Racing 4 Point Rear Lower Arm Brace. First off is the review. There is a definite increase in steering control. I took it on a test drive, and I happened to take some corners at some fairly high speeds. (50-60mph on a 110 degree corner) The bar helps keep the car planted to the ground, and it does help take the corners at a higher speeds. I just install this so I will make a future review when I do take the corners on some auto cross and track courses. Another thing is that the brace does touch the bottem of my exhaust. There is a slight vibration, and there is an increase in noise during pre accleration or during WOT.
On to the DIY. It is a fairly easy install. Only 4 bolts and some simple tools should do the job.
Tools:
14mm deep socket
17mm deep or shallow socket
1/2 or 3/8 ratchet (whichever you prefer)
The Bar:
Step 1: Remove the 14mm bolt that is on the lower control arm that is connected to the rear sub frame.
Step 2: Remove the 17mm bolts that are on the side that connects the rear lower sub frame mount to the frame.
Step 3: Place bar in its place and install all the bolts back in its original place. Finish product is as shown.
« Reply #1 on: October 28, 2010, 11:29:15 PM »
Good write up Thien.  Looks like a quick 15 minute install.
« Reply #2 on: October 28, 2010, 11:34:16 PM »
Pretty much it is. With the air tools I have, it took me like 5 minutes.
Milan pfffft.
« Reply #3 on: October 29, 2010, 11:19:29 PM »
Very niiiiice, how muuuuch??
« Reply #4 on: October 30, 2010, 04:00:12 PM »
The bar itself cost $159 shipped.
neoryan7
neoryan7 pfffft.
« Reply #5 on: November 01, 2010, 06:13:38 PM »
Looks like its touching your exhaust. Is that what is causing the vibration and noise? approx how heavy is it?
« Reply #6 on: November 01, 2010, 07:16:18 PM »
The exhaust is touching the bar and thus causing the vibration and noise. The bar itself is very light. I would say the bar is roughly about 2 lbs if that.
neoryan7
neoryan7 pfffft.
« Reply #7 on: November 13, 2010, 11:56:20 PM »
How is this holding up? BTW did you get the one for the sedan or is this the tsx one?
« Reply #8 on: November 14, 2010, 12:00:44 AM »
It is holding up great, and I got the one from the Accord sedan. Its cheaper by like $20.
sgrab
sgrab pfffft.
« Reply #9 on: December 14, 2010, 02:53:50 PM »
Any new updates? Im looking into a similar product.
06RockHead
06RockHead pfffft.
« Reply #10 on: February 09, 2013, 03:20:47 PM »
Does this also fit the coupe? Or is there a difference
« Reply #11 on: February 09, 2013, 04:10:44 PM »
Thien's car was a coupe, so I would say yes, it does.
« Reply #12 on: February 09, 2013, 10:34:44 PM »
They are the same.
06RockHead
06RockHead pfffft.
« Reply #13 on: March 06, 2013, 01:02:03 PM »
ok thanks guys im slowly creating a mountain of parts for the spring
olecram39
olecram39 pfffft.
« Reply #14 on: November 19, 2013, 06:06:14 PM »
I was going to make a new thread but i figured i would post here first and if anything it can be separated later if it escalates.
I saw this brace and other similar components online and i thought, is it possible to make one of these? I have a bunch of metal pipes and metal bits and pieces back home, as well as a welder. The design of these things seems pretty simple so i was thinking about making one. Or maybe the simpler designs such as these.
What do you think? It would be way cheaper.
Oh and I saw this video that can help with the installation mentioned in the OP as well.
Performance Bracing
