August 26, 2026, 09:26:20 PM
Fueling car while running
Topic: Fueling car while running (Read 30542 times)
Re: Fueling car while running
July 30, 2010, 10:50:45 AM »
then leave your car running, as you can tell we dont think its wise and to each his own. i hope we dont have to say we told you so, but in that event we wouldnt get to anyways.
July 30, 2010, 10:53:12 AM »
Quote from: CheaperIsBetter on July 30, 2010, 09:13:08 AM
If the cars evap system doesn't work while not at vacuum then there is still the gas pumps vapor recovery system. Most of the inccidents when there were ignitions were in years past and fuel pump manufactures have advanced their vapor recovery systems since these incidents. Now if you're overfilling after the pump clicks there might be more fuel in the air, and not releasing built up static or wearing garments that produce extra static can still ignite fuel and air, but if ignitions were a more common occurence don'you think we'd be hearing about it more; I'm sure people leave their cars running accidentally all the time.
-And since static charges are the predominant cause of ignitions, why does leaving your car running increase the risk of one?
Why are you guys so scared?
Scared? It's just not smart! Hold on let me change my shirt to something non static to pump my gas! This thread is a waste of space, and when people give you facts(EVAP system operation) you bring up more crap. How about the fact that you risk damaging the EVAP system becase the ECU is trying to operate, and cannot do so. Have you ever replaced any parts of an EVAP system? I have and can tell you that it sucks, and it's expensive!
Last Edit: July 30, 2010, 10:55:46 AM by lavalleemike
July 30, 2010, 10:55:33 AM »
Quote from: lavalleemike on July 30, 2010, 10:53:12 AM
Scared? It's just not smart! Hold on let me change my shirt to something non static to pump my gas! This thread is a waste of space!
Mike, we do have a magic little button at our disposal to remedy that.
July 30, 2010, 10:59:00 AM »
It's a valid question to ask at the end of the day. But, to put it simply if you check engine light comes on because of it it's probably not a good thing to do. It's like unplugging a sensor becase you don't like the color of the wire (Pointless).
July 30, 2010, 12:11:49 PM »
So, let's get this straight. You posted a thread asking for opinions. Then you criticized and ignored those opinions and said you were going to do what you wanted anyway. Why are you looking for validation to do what you want and masking it as asking for an opinion? What was the point of posting this? Did you just want to argue with people?
CheaperIsBetter
July 30, 2010, 03:51:02 PM »
Ok, let me elaborate on the intentions of my post.
I wanted to see what people thought, and I wanted to have a discussion about how or why people felt the way they do and establish some truths about the topic.
Like I said I have been leaving the car running while re-fueling and I was surprised that most people prefer to turn their vehicle off. It turned into people calling me out for stupidity and I tried to defend my actions as acceptable.
What I was ardently trying to assert was that leaving your car running was not physically dangerous, not that that is the better method. I did research and found that the evap system on a car can throw a code while the tank is not at vacuum, but nowhere did it say that leaving the car running increased the chances of an ignition. My 2005 V6 did not throw a code (Although I assume it would if I drove without the cap on) so I assume your V6s and maybe your I4s would also not throw any codes. The arguments for turing your vehicle off were that you saved fuel, to prevent the car from slipping out of gear, and that it prevented you from throwing a code and requiring up to a $150.00 service charge for the dealer to diagnostic your car and turn the code off. Those of us with our own diagnostic tools or access to a nearby Advance Auto Parts would be able to clear the code ourselves if indeed a code was thrown.
With the only cases of ignition I've found being related to a static electricity discharge I failed to find any information that explained how leaving your car running would increase the chances of a static or other type of ignition.
Most of the responses I got didn't pose any real commentary on the issue other than that they would rather not risk it or that I was an idiot. Mike did bring up that it could damage the evap system and require an expensive repair - which I had not considered before and appreciate.
I like this forum and the people in it, and didn't mean to come off as an asshole or know it all. I value the information that it has to offer. Please forgive me for my trespasses, and let us continue a meaningful exchange on this topic and others.
July 30, 2010, 05:36:50 PM »
To be honest, it just doesn't seem like a good idea to leave your car running. The possibility of it getting stolen is a concern of mine. The fact that it could also affect your evap system is another consideration that should be made. In all honesty, I would say that it's not a very wise practice to fill up with the car running. That's just my opinion which is not solely based on whether or not I'll be turning my car into Accord Flambe if I don't shut it off while filling up. To me, it just seems like a very bad idea.
July 30, 2010, 05:52:10 PM »
I'd have to agree with Tim.
Now I don't mean to take a left turn with this, but what about diesel? Isn't diesel harder to ignite? The only time that I remember actually filling up diesel while the vehicle was running was my stepdad's 2007 F250. That thing was having so many problems... the truck wouldn't be able to start back up if we turned it off. That truck is long gone now, haha. I always hear people saying that diesel is a lot safer than gas.
Either way I would never leave my car running while fueling up, regardless of whether or not it's safe. I'd rather not have someone jack my car while I'm fueling up his getaway.
Reply #23 on:
July 30, 2010, 07:05:20 PM »
Diesel fumes are less dense which makes them less flame able chemically. I didn't mean to take a shot at you personally, and Mythbusters did a special on ignition at gas pumps which my be worth getting your hands on. You have a V6 so I will tell you that I'm had my charcoal canister replaced, and it's cost me $320. I did play some labor on that installation because Paul (NVA-AV6) told me the work was a nightmare to do, and for some reason my local dealer misquoted the labor and, only charged me a half hour for a 3 hour job. I've done VSV valves on a Camry in the past, and they are generally difficult to get a hold of(don't fail commonly), and expensive.
Reply #24 on:
July 31, 2010, 11:49:16 AM »
I'll be honest here. The only time I've left my car running is when I have to stop for gas with the wife and spawn in the car. I leave it running so they don't cook inside because as many of you know, I live in Miami. I'm not promoting it in any way. The wife also knows to shut the car off and pull the key out of the ignition if I give the signal. Like the OP, I've never gotten a MIL or the sort. As far as ignition and having an Accord flambe, as Tim so eloquently put it, you'll still have that regardless of the vehicle running because the pump is still releasing fumes while you fill. Food for thought.
CheaperIsBetter
Reply #25 on:
October 20, 2010, 10:14:59 AM »
In Case of Fire:
http://www.break.com/index/dumb-woman-pushes-fire-button.html
I love women....
Reply #26 on:
October 20, 2010, 05:21:41 PM »
There's a "fire" button at fuel pumps?
CheaperIsBetter
Reply #27 on:
October 20, 2010, 06:04:44 PM »
Yeah; apparently there are where this woman lives.
You can see her looking at it and reaching in to push it; what does "FIRE" on a red button mean...let's find out.
status
GOMD
Reply #28 on:
October 20, 2010, 06:25:14 PM »
hahaha i wish we pumped our own gas here so i could do that.
-Alec
Reply #29 on:
October 20, 2010, 08:03:03 PM »
You don't pump your own gas?
