November 08, 2026, 03:18:26 AM
Brakes
How To: Rear Drum To Disc Conversion
Topic: How To: Rear Drum To Disc Conversion (Read 131794 times)
Re: How To: Rear Drum To Disc Conversion
Reply #45 on:
April 08, 2012, 02:05:39 AM »
What was the rough cost of the entire project?
Reply #46 on:
April 08, 2012, 08:24:26 PM »
Plan on spending about $250-300 when you take into consideration the cost of all the parts involved. Here's what I paid:
$100 - both rear knuckles
$100 - both rear calipers w/parking brake cables (had to replace the cables later on)
$10-20 - proportioning valve
$50-100 - rotors and pads
theycallme_og
not that kind of OG
Reply #47 on:
January 02, 2013, 02:24:32 PM »
Timothy, so I am planning to do this project but I had something a bit different If possible, I would like to swap my entire brake setup for a 08 TL Type-S. I found a wrecked one nearby where I live and could pick up all four brake calipers (Brembos) both rear knuckles and front brackets needed.. And the junk yard place is telling 800 for everything.
What do you think, is it possible? And is it. Good deal?
Reply #48 on:
January 02, 2013, 02:49:33 PM »
It may be possible. I've never done it myself though. The Brembo front brake set up from a TL Type S may not be a direct bolt on to the Accord knuckles. At that point you would have to swap out the TL Type S knuckles and possibly the upper and lower control arms. That would end up affecting the geometry of your suspension. From what I recall your wheels would be pushed out and you would have excess negative camber for a street car.
I don't think anyone has done this on an Accord yet. I only know of one person that did this on a 1st gen TSX, but he swapped out the sub frame and had it modified for the proper geometry.
theycallme_og
not that kind of OG
Reply #49 on:
January 02, 2013, 04:06:28 PM »
darn I was hoping it would be simple swap..
But to be the first person to do this would be kind of cool
Reply #50 on:
January 02, 2013, 06:42:16 PM »
Give it a. Try and let us know how it works out. Nobody will ever know until you try it. I didn't mean to discourage you. I say go for it if you're willing to invest the time and energy on attempting it. Just be sure to plan for problems.
ADI
Reply #51 on:
January 03, 2013, 01:17:31 AM »
Quote from: theycallme_og on January 02, 2013, 04:06:28 PM
i have seen it done before on a v6 accord coupe, the person that did the swap mentioned that the parts needed would be:
Acura TL/TL-S 04-08
45018-SEP-A60 Right Caliper $300+-
45019-SEP-A60 Left Caliper $300+-
44600-SEP-A01 Hub x 2 $42+- x2
51210-SEP-A01 Knuckle Assembly Right 206+-
51215-SEP-A01 Knuckle Assembly Left 206+-
Stainless steel Brake lines $100
pads 60-300 depending on pad choice
rotors 100x2
those prices are assuming you buy them new, but from a junkyard much cheaper.
couldnt find any close up pics of the brakes (for some reason the thread were i found the info is no longer up ) but if you look closely you can see the calipers and i know for a fact they are the tl-s brembos as i have seen the car in person and know the owner.
Reply #52 on:
January 03, 2013, 03:46:49 AM »
The rear brakes won't be an easy task to do. The Accords uses an integrated e-brake caliper while the TL uses an e-brake shoe. You would need to swap e-brake cable, knuckle, rotors, calipers, and the porportioning valve.
theycallme_og
not that kind of OG
Reply #53 on:
January 03, 2013, 11:09:16 AM »
Wow, thanks guys very informative. I will hold back right now since money is tight but once I pull the triger to buy all the parts needed I will definately do a write up on this.
Re: Re: How To: Rear Drum To Disc Conversion
Reply #54 on:
January 03, 2013, 11:41:10 AM »
If you don't want to deal with the mess that Thien mentioned, you could always ask Paul for one of his brackets, and use Honda Pilot rotors in the rear. I don't remember if we have a thread for that option though. That way you still get a performance increase in the rear.
Reply #55 on:
February 08, 2013, 11:10:44 PM »
Well, I think I'm ready to get this project going soon (maybe start next weekend), so I want to make sure I have all my ducks in order as this task is going to be 50% preparation. Below is, I think, a complete parts list, but feel free to chime in before I whip out the Visa. I think I'm opting against the bigger Pilot rotors and Paul's brackets and just gonna go with an EX-equivalent setup as I just have the Legend setup up front. I'm also going aftermarket on my rotors and pads to match my fronts, so that'll up my costs a bit. Check list below:
Right rear knuckle 52210-SDC-A60 (
already acquired
Left rear knuckle 52215-SDC-A60 (
already acquired
Right rear caliper 43018-SDA-A00 (
get brand new or remanufactured? Doesn't seem to have much of a price difference.
Left rear caliper 43019-SDA-A00 (
Rear hub unit bearing assembly 42200-SDA-A51 x2 (
I think I already have these too
Hub unit cap 42326-SLJ-000 (x2)
Rear brake rotor 42510-SDA-A00 (x2) (
going with Accord EX equivalent aftermarket EBC Ultimaxx setup to match fronts and be baller
Right rear splash guard 43253-SDA-A51
Left rear splash guard 43254-SDA-A51
Flange bolt 90103-SV4-013 (x4)
Spindle nut 90305-S30-003 (x2)
Flat screw 93600-06014-0H (x4)
Flange bolt 95701-06012-08 (x6)
Right parking brake cable 47510-SDA-A52
Left parking brake cable 47560-SDA-A52
Four-way joint 46470-S5T-E01 (
you really need this? Is this the EX proportioning valve?
Right rear brake line set 01466-SDA-A50 (
would like to go stainless steel... anyone have a set to sell?
Left rear brake line set 01468-SDA-A50 (
Proportioning valve 46210-S5A-812 (
I think this is the right one... but it's $55 now?! Actually, this might be for the LX.
Anything missing from this list, or other little odds, ends, bolts and screws I should invest in just to be safe?
Also still need:
flare nut wrench
impact socket
couple bottles of brake fluid
caliper paint
brake fluid bleeder bottle
anti-anxiety medication
My goal is to start this swap next weekend, work on the car when I can, and experience no more than 2 weeks downtime. Anyone local want to help for cash, food and beer? Heated garage.
Last Edit: February 09, 2013, 02:02:23 AM by striktlyaccord
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Reply #56 on:
February 09, 2013, 12:47:47 AM »
I might have a little time next sat.
Lemonjelly
Reply #57 on:
February 09, 2013, 07:59:40 AM »
From what i remember from doing tims swap and from planning this swap my self a lot of the bolts and what not carry over. Im up in maine for the weekend with only my phone but once i get back home ill dig back through my notebooks and see if i can find all the part numbers for what i was planning and compare it to your list. I should be around next weekend to help but i cant do a lot of heavy work with my bum shoulder right now but i can provide emotional support/be a tool bitch/technical consultant.
Let me know time and place.
Steve - NECM #4
Reply #58 on:
February 09, 2013, 08:44:21 AM »
Here you go Dave.
Quote from: striktlyaccord on February 08, 2013, 11:10:44 PM
already acquired
already acquired
- get new if there's an insignificant price difference
- these are already in the knuckle
BUY THIS ONE
- buy a full set and sell the fronts
DO NOT BUY THIS ONE
- Since I know you well enough, get a big fucking bottle of this stuff.
Reply #59 on:
February 09, 2013, 10:37:38 AM »
Thanks for the check list corrections. I was 90% right about what was needed verses not, but posted everything just to be safe. Ordering stuff now since there's nothing else to do other than shovel right now.
--Dave--
NECM Squad
Profile & Mods List
