September 30, 2026, 04:38:29 PM
Does this problem have to do with alignment? something else?
Topic: Does this problem have to do with alignment? something else? (Read 16867 times)
rich
Re: Does this problem have to do with alignment? something else?
June 09, 2010, 09:49:52 PM »
turns out it was the alignment and bad tires. i got brand new tires and mount/balance and alignment monday morn. feels like a new car!
the only bad thing he says my cv joints (4 up front) are going bad..doesnt need to be fixed asap but does need to be fixed. ill probably have them do it once its time to get my tires rotated
2004 Accord Coupe V6 6speed
for sale!
June 17, 2010, 06:05:56 PM »
I have a similar problem,
I just got an alignment after lowering + rims + camber kit... Rear is at OEM camber and toe specs, Front is -0.7 camber both sides and OEM caster spec EXCEPT right side has 7 extra than the left (so some cross caster here)...
What happens when I drive is, it won't really pull per say but putting the steering wheel straight goes left easily, so on most roads I have to drive with the steering pointed to the right, im not sure what this is dependant on as on the highway i need to have it turned more than say on a regular street... A street with slope to the right needs less, street with slope to left needs more.. There is no sweet spot and I have to adjust constantly (I am used to it though)
Prior to lowering, rims, camber kit, On my winter tires they would have the same problem except opposite direction... Back in the day with OEM tires they did this too ( I think after a rotation they changed directions again), those tires are bald now but wore evenly
Any ideas? Not rotating often enough? Axel, ball joints? Stuff I can check myself will be great. I can remove the wheels and rotate them around if that helps (or to see if they change direction again)
If there is nothing to be done, I can live with it as long as my tires wear evenly.
FYI also just replaced front lower driver control arm when I got lowered!
June 17, 2010, 06:14:40 PM »
If you can, show us your alignment printout from when you got your alignment. That way I can elimante what is causing your pull. It could be the tire itself.
June 17, 2010, 07:13:03 PM »
Quote from: "MyNameIsThien"
Tires weren't doing this before the drop, camber kit, alignment (they did the opposite direction like the winter tires that were on before)
Don't got a printout but I memorized it pretty much
Front:
Front didn't get any adjustment as far as I recall
Camber
-0.7 -0.7
Toe
0 0
Caster
3.0 3.7
Rear:
Camber
-1 -1 (-2.5 -3.3 before for two weeks after camber kit install)
Toe
0.15 0.15 (something crazy before, for two weeks after camber kit install)
June 17, 2010, 08:43:32 PM »
On the front toe, is that total toe or individual toe? Who installed your suspension?
June 17, 2010, 08:48:39 PM »
should be individual, some brown guys with a shop installed my suspension (know them through family)... they aren't the best
but given the problem existed to an extend before i got suspension and stuff, lends me to believe the install was not the issue
June 17, 2010, 09:15:48 PM »
Quote from: "Asim"
June 17, 2010, 09:25:07 PM »
Quote from: "Asim"
its not like they had to assemble my shocks and springs, they just had to remove and replace the old strut with my new ones
Reply #23 on:
June 17, 2010, 09:29:12 PM »
Quote from: "Asim"
You gotta watch out for them brown people.
Reply #24 on:
June 17, 2010, 09:37:13 PM »
Quote from: "Asim"
My own kind are a burden!
Reply #25 on:
June 17, 2010, 10:02:11 PM »
What are brown people?
Reply #26 on:
June 17, 2010, 10:38:02 PM »
Quote from: "wtcii"
pakistani (like me and those guys), indian, etc
Reply #27 on:
June 18, 2010, 10:03:58 PM »
Ah, ok. Thanks!
Reply #28 on:
June 18, 2010, 10:20:13 PM »
Wait, do Latino's count as brown too?
Last Edit: June 18, 2010, 11:18:44 PM by sherker55
Reply #29 on:
June 18, 2010, 10:41:50 PM »
Yeah, that's what was throwing me off.
