June 27, 2026, 03:06:15 PM
Wheels & Tires
G35 Wheel Opinions
Topic: G35 Wheel Opinions (Read 25764 times)
Re: G35 Wheel Opinions
April 22, 2010, 07:04:58 PM »
arent the rims on that g35 forged rays??? if so, paint gun metal.
Accord Euro-R
April 22, 2010, 08:03:06 PM »
Quote from: "fabulous010"
i like the ti-5 golds
That was my feeling...the blue w/ gold wheels is typical of J.D.M cars. My only issue is that the gold with the neo chro lip might be too much...
Euro
R
" Concept - USDM CM82
April 22, 2010, 09:00:56 PM »
Yes
April 22, 2010, 11:58:57 PM »
wow, all of those wheels are really really really fucking ugly...I saw the pic of the car and was like "nice" then I saw your wheel choices, and I threw up in my mouth. I'd put the money into suspension and performance. God those wheels are FUGLY! Keep them stock and PC them gun metal like mentioned, or the NISMO ones that Tim posted are sick, but I would keep them stock. I can't even believe that companies make wheels that look like that, those colors and rainbow shit, well I think I've said enough. Good luck
April 23, 2010, 08:52:05 AM »
If she wants the TI look these are the
ONLY
wheels I would consider!
April 23, 2010, 09:15:52 AM »
Post a picture of the stock wheels. If they are the 19" Rays Forged please, please, don't get any of the ones you posted. The stockies own all the ones you posted.
Accord Euro-R
April 23, 2010, 10:14:11 AM »
OK here the thing...she is looking at 2 different G35's right now. They are literally the exact same car, except one has about 4k less miles and different rims.
Car with more miles, but closer location: (Chantilly, VA)
OEM 17x7
Car with less miles, but further away & more expensive: (Irving, TX)(Pictured above)
OEM 19x8
Euro
R
April 23, 2010, 11:34:36 AM »
car pictured, better wheels, less miles...newer too, $ difference?
Reply #23 on:
April 23, 2010, 11:42:12 AM »
Get the car with the stock 19s, use the money you would have spent on the rims and tires.
/thread.
Accord Euro-R
Reply #24 on:
April 23, 2010, 11:44:18 AM »
Quote from: "sherker55"
Chantilly, VA:
2007 G35 Coupe w/ Premium & Navi Packges
37,282 miles
Only a 6.5 hour drive
Smaller OEM wheels
$25,995 (Negotiable)
Irving, TX:
2007 G35 Coupe w/ Premium, Navi, & Sport Packages
23,497 miles
16 hour drive
Larger OEM wheels
$26,998 (NOT Negotiable)
Euro
R
phunctional
Reply #25 on:
April 23, 2010, 12:46:45 PM »
Tires, P225/50VR17 Front & P235/50VR17 Rear is what i see for the specs of the one you claim has 19"s, so it pretty much comes down to which style rim you like now, both are 17"s
CM82
Reply #26 on:
April 23, 2010, 02:05:25 PM »
Negative Ghostrider. The ones in the original pic he posted are most definitely 19's. Those are Rays wheel as opposed to the Enkeis(?) that are 17's.
phunctional
Reply #27 on:
April 23, 2010, 02:42:31 PM »
must be a pretty big stretch to get some 17" tires on 19"s
CM82
Reply #28 on:
April 23, 2010, 03:11:33 PM »
Quote from: "phunctional"
I'd like some of what you're smoking. As already stated before, the G35's come with both 17's and 19's depending on the wheel package. Are you just not accepting what you're being told, or do you live in an alternate reality?
Reply #29 on:
April 23, 2010, 04:30:59 PM »
I agree with Tim.. It's Friday, and I'm hella tired so I could really use some of what you are smoking..
Here were the G35 wheel options:
Quote
source=
http://www.350z-tech.com/zwiki/Wheel_Specifications
This section contains information on the Infiniti G35 wheel options. Here you can verify wheel sizes and offsets, tires sizes, and even wheel weights, providing a good starting point for aftermarket wheel comparisons.
Standard 17"
Base model G35 17" wheels
Aluminum Alloy
Front
Offset: +30mm
Weight:
Tire: 225/50/17
Rear
Offset: +33mm
Weight:
Tire: 235/50/17
18" v.1
Standard G35 18" wheels
Aluminum Alloy
Front
Offset: +30mm
Weight:
Tire: 225/45/18
Rear
Offset: +30mm
Weight:
Tire: 245/45/18; 265/35/18 will also fit
Rays Forged 19"
Optional 19" G35 forged wheels
Super-Light Weight Forged Aluminum Alloy
Front
Offset: +30mm
Weight: 19 lbs
Tire: 225/40-19
Rear
Offset: +33mm
Weight: 21 lbs
Tire: 245/40-19
