December 15, 2025, 03:50:14 PM
ECM Chatroom
316
317
318
319
1911
Topic: ECM Chatroom (Read 6571450 times)
0 Members and 16 Guests are viewing this topic.
Re: ECM Chatroom
Reply #4740 on:
May 20, 2010, 02:28:42 PM »
As do I. On another note, the idea of doing a 6 spd j30 has been dancing around in my head for when I come back. I know there would be quite a bit involved in making it work but that doesn't seem to dissuade me in the least. Could I possibly have a few screws loose for having this idea and even thought out everything involved?
Of course you have several screws loose, if you're going to do a J30 6spd swap, why not just go for a J35 already?
Re: ECM Chatroom
Reply #4741 on:
May 20, 2010, 02:31:13 PM »
It would be more economical to sell your car and buy one.
Re: ECM Chatroom
Reply #4742 on:
May 20, 2010, 02:36:59 PM »
Quote from: "Mr Eazy"
Yet another thought that crossed my mind.
I knew someone would say that. I'm making payments on my car and I got into it upside down. Wouldn't be that economical for me. Buying a wrecked v6 6spd coupe and pulling what I need for the swap seems like a more feasible option. Besides, how many 05 v6 6spd sedans do you know of?
Re: ECM Chatroom
Reply #4743 on:
May 20, 2010, 02:52:47 PM »
It would probably be cheaper to fix the wrecked one. Everything is different suspension brakes etc.
Re: ECM Chatroom
Reply #4744 on:
May 20, 2010, 02:53:28 PM »
You could just build your K.
Re: ECM Chatroom
Reply #4745 on:
May 20, 2010, 02:55:38 PM »
I'm aware of what's different. I was saying pulling the stuff out of the wrecked one and putting it into my car. A full on v6 6 spd conversion. The coupe doesn't suit my needs anyway. I have the spawn to cart around. The way this would come out cheap is if I were to pick up a car that was totaled out and salvage EVERYTHING from it.
That was my original intent. Now I have other ideas dancing around. The good thing is that my car is mostly stock so whichever route I choose I basically have a clean slate.
Re: ECM Chatroom
Reply #4746 on:
May 20, 2010, 02:59:25 PM »
You would have to find something that was rear ended. It would be a project thats for sure.
Re: ECM Chatroom
Reply #4747 on:
May 20, 2010, 03:02:09 PM »
Exactly my thinking. Not going to be easy but I have at least a year to figure out what I want to do.
Re: ECM Chatroom
Reply #4748 on:
May 20, 2010, 03:06:03 PM »
If I were you I would do a TSX 6 speed swap with LSD, and a turbo K series. Cham's numbers where nothing to shake a stick at, and the money you would be putting into a J30 swap would probably be approx. equal to a build like this.
Re: ECM Chatroom
Reply #4749 on:
May 20, 2010, 03:39:16 PM »
I don't question that the J Series motors are capable of making power. My main concern is that there aren't as many options for aftermarket equipment for the J's compared to K's. The other major detractor for me is tuning. There is no J Pro yet. All the other EMS options that I know of lack one thing, you can't advance the timing. You can only retard the timing. I know that not having the ability to advance the timing will hurt your performance.
If I was going to build a turbo K series, I'd keep the 5 speed tranny actually. You don't want short gears with a turbo. For n/a and SC motors, shorter gears are ideal though.
Re: ECM Chatroom
Reply #4750 on:
May 20, 2010, 04:28:39 PM »
Yeah, I was actually thinking of all of that. I do want to go with a snail if I kept my k and would most definitely keep the 5 spd with an RSX flywheel and upgraded clutch. The EMS options for the k is what's steering me to keep the k but who knows what will be available when I return. Just shit for me to ponder over.
Re: ECM Chatroom
Reply #4751 on:
May 20, 2010, 05:16:15 PM »
What a fucked up day...I'm sick but I'm going drinking after work.....T-15 minutes.
Re: ECM Chatroom
Reply #4752 on:
May 20, 2010, 05:29:26 PM »
T-2 minutes as of this posting for ya.
Re: ECM Chatroom
Reply #4753 on:
May 20, 2010, 05:38:17 PM »
T-8 minutes and then I get stuck with needles.
Re: ECM Chatroom
Reply #4754 on:
May 20, 2010, 08:51:54 PM »
Getting stuck with needles isn't good. What's up?
316
317
318
319
1911
