September 24, 2026, 02:53:51 PM
Grounding
Topic: Grounding (Read 12941 times)
Grounding
March 22, 2010, 02:48:35 PM »
I did a grounding kit on my car this weekend, J30, and I haven't noticed any results. What are some things that I
should
be noticing?
Re: Grounding
March 22, 2010, 02:59:16 PM »
I was under the impression that they are supposed to help your audio setup or something...
Re: Grounding
March 22, 2010, 03:09:52 PM »
There are alot of claims out there. More hp/tq, better mpgs and better audio clarity. I'm not sure which of these are actually true though.
Re: Grounding
March 22, 2010, 07:02:40 PM »
Have any pictures? how many points did you ground? when i did my car i swap out all the stock and replace with a heavier gauge all i notice was smoother start ups
Re: Grounding
March 22, 2010, 07:15:24 PM »
path 1) neg to strut tower
path 2) neg to block head, blockhead to IM, IM to strut tower, strut tower to alternator
I will get some pics if that will help?
Re: Grounding
March 22, 2010, 07:29:49 PM »
I seen different people do it different ways and everyone has mixed reviews about it might be all personal preference i did this along with the big 3 upgrade and grounded 7 points and all i have notice are the smoother start ups
Re: Grounding
March 22, 2010, 09:01:39 PM »
Pics in order from point to point, starting at the battery:
Re: Grounding
March 22, 2010, 11:09:46 PM »
Meh. You're probably not going to notice much of a difference except for your electrical components working a little better at idle and starting up, like Clemente mentioned.
Re: Grounding
March 22, 2010, 11:54:31 PM »
I even tried turning on the A/C to see if it "kicked in" any smoother. I really can't tell. Seems like the grounding from the factory is sufficient.
Re: Grounding
March 23, 2010, 08:07:40 AM »
You'll probably notice that your lights don't dim as much when you turn on an additional electrical load (i.e. a/c).
stirfriedferret
Re: Grounding
March 23, 2010, 01:16:23 PM »
I've also heard that when you setup a grounding kit like that, it's better to have one ground wire go to each point instead of making it one long chain.
Brian
SoCalCM Squad
EliteCM Profile
Re: Grounding
March 23, 2010, 01:27:34 PM »
True that!!
Re: Grounding
March 23, 2010, 11:07:54 PM »
Quote from: "stirfriedferret"
that would be one big ass clump of wires from the neg battery terminal...
Re: Grounding
March 23, 2010, 11:24:07 PM »
They have grounding kits that mount to your negative battery terminal that have multiple mounting points for you to run a ground to different locations in your engine bay. I need to get my ground kit/voltage stabilizer back in my car.
Re: Grounding
March 23, 2010, 11:38:47 PM »
this is how mines looks with voltage stabilizer and grounds i tucked most them away to give it a somewhat clean look
