August 29, 2026, 12:14:35 PM
496
497
498
499
Topic: What did you do to your Gen7 today? (Read 3684087 times)
Reply #7440 on:
January 28, 2014, 09:30:50 PM »
If you use a heat gun (or hair dryer) to heat up the area and the adhesive tape first, it will adhere better.
Reply #7441 on:
January 28, 2014, 09:41:54 PM »
I totally broke out the blow dryer!
Reply #7442 on:
January 28, 2014, 10:24:46 PM »
Giggity?
Reply #7443 on:
January 28, 2014, 11:54:09 PM »
I posted this in my profile thread, but I figured I would post a few pictures of what I did yesterday.
I pulled out the grinder and cutoff wheel to gain some extra clearance with the Xcessive runners that are the beginning of my new intake manifold. After I got my water pump to clear the runners, I discovered that I had to do some more cutting and grinding to make room for the lower fuel rail that will feed the second set of injectors. Here are a few pics of the progress.
Reply #7444 on:
January 30, 2014, 07:24:15 PM »
took the car out for a drive. My Power Steer is F'd. making a really loud whine like a super charger.... hopefully new fluid and oring will help. When I turn the steering wheel it also causes the RPM to drop and rebound back up. So might also be a dead sensor...
Last Edit: January 30, 2014, 07:34:40 PM by thisaznboi88
Reply #7445 on:
January 30, 2014, 07:42:22 PM »
Quote from: thisaznboi88 on January 30, 2014, 07:24:15 PM
Ken, if you do not already the orange o-ring for the pressure line, this will happen. There was a TSB a few years back for this. The oringinal o-ring is black and was proven to not hold up over time during extremely low temps. I had to warm up my car for 45mins. + sometimes for it to cut down on the whinning lol. It's a $3 o-ring and 5min. fix.
Reply #7446 on:
January 30, 2014, 08:14:55 PM »
yeah I getting the newer one. i order it from Honda. I forgot to ask how much. but 3 dollar is fair. The fluids were like 4.50 a bottle and I am getting 2. Going to empty the reservoir and then put new one in. move the steering from lock to lock left and right. take it for a driver and drain it again. So that its 90% new fluid inside.
maybe this way is a little better?
Honda Power Steering Fluid Change
Last Edit: January 30, 2014, 08:23:08 PM by thisaznboi88
Reply #7447 on:
January 30, 2014, 09:27:09 PM »
Mine does the same thing but i haven't gotten around to changing the o-ring. Ken do you know the part number on that o-ring?
Reply #7448 on:
January 30, 2014, 09:44:58 PM »
here ya go bud
O-ring
91345-rda-A01
P/S fluid is 08206-9002
Last Edit: January 31, 2014, 08:18:18 AM by thisaznboi88
AccordEX
Reply #7449 on:
January 31, 2014, 12:11:44 AM »
Cleaned a little under my hood. Cleaned the interior. Need help removing driver side window tint glue.
A man once told me... if ummm.... forgot.
Reply #7450 on:
January 31, 2014, 10:16:33 AM »
Test fit my new radiator and started working on my k20a2 shift mechanism swap.
Reply #7451 on:
February 01, 2014, 03:03:09 PM »
changed out my power steering oring and new fluid. it was black.. and now its clear. also solved my random idle issue. 2 bottle was enough. also found out I order the wrong belt for my car.
Reply #7452 on:
February 01, 2014, 03:05:36 PM »
Made my new radiator fit properly. I also marked it for the new mount placement.
Reply #7453 on:
February 01, 2014, 03:12:07 PM »
Took the RDX to the car wash, flushed the clutch fluid and then hand washed the accord. I hope this solves my shifting issues when it's cold. Changing the MT tranny fluid didnt help. On to the next project...
olecram39
Reply #7454 on:
February 04, 2014, 09:25:57 PM »
Installed a bike rack so i can carry my drift trike around and my regular bike.
496
497
498
499
