October 27, 2026, 07:06:43 AM
Pages: « First < Previous 1 ... 491 492 [493] 494 495 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3802111 times)
0 Members and 36 Guests are viewing this topic.
Arielit0oo pfffft.
« Reply #7380 on: December 22, 2013, 08:30:31 PM »
^What're you, driving down the block every other day?
« Reply #7381 on: December 22, 2013, 09:27:38 PM »
Not using it. Using mass transit as much as possible to keep the mileage down.
Arielit0oo pfffft.
« Reply #7382 on: December 22, 2013, 09:54:10 PM »
When are you going to mod that poor thing?
« Reply #7383 on: December 23, 2013, 07:06:08 AM »
Never. He's going hipster/ homo and picking up a mini cooper.
Arielit0oo pfffft.
« Reply #7384 on: December 23, 2013, 12:16:57 PM »
Smh. Nelson, sell the Accord to someone who will treat it well.
« Reply #7385 on: December 24, 2013, 10:50:32 PM »
I'd treat it well, I just don't want another car ATM.
I dropped off my the beginning of a new water/ice tank. Had to test fit it and make sure everything was right while it was only tacked up. All the finish welding will be done on it by Friday, the an fittings will be welded on and the opening for the cap will be cut out. With some quick and dirty math, I figure this tank should hold at least 10-12 gallons of water or about 50-60 lbs of ice.
Ryan, you'll need to empty out your freezer when I come to get tuned again.
« Reply #7386 on: December 29, 2013, 02:26:41 PM »
Took the front end apart only to put it back together for the second time now.
Been having a lot of paint issues with my retrofit project. I plastidipped the bezels last night, only to find out the finish was all fuzzy and not smooth. Turns out I was spraying too far away from the part. Now I have to peel it all off and do it over again. With the amount of money I've been spending on paint/plastidip, I probably could have afforded a TL retrofit. -_-
« Reply #7387 on: December 30, 2013, 12:18:26 AM »
Brought my kpro to have some things changed on my CAN module.  A VSS out was added to my ECU for cruise control to work and then the CAN module was reflashed for my new final drive and gear ratios.
« Reply #7388 on: December 30, 2013, 11:10:31 AM »
Oil change, tires, and an alignment...
« Reply #7389 on: December 30, 2013, 11:42:05 AM »
Installed a clip on mirror..lol
« Reply #7390 on: December 30, 2013, 08:35:14 PM »
Ordered a wheel stupid new England roads
« Reply #7391 on: December 30, 2013, 09:48:58 PM »
Ordered a piece of hot pink vinyl in gloss
« Reply #7392 on: December 30, 2013, 10:45:23 PM »
Pulled my TVS off the mock up motor.  I tried to get an idea of how much space I have for a new intake manifold.
« Reply #7393 on: December 31, 2013, 10:09:36 AM »
What happened and where did you order from?
« Reply #7394 on: December 31, 2013, 11:54:11 AM »
had to get new tires one of them was bent pretty bad when they balanced. Shaking up and down plus left and right. Ordered on eBay... Cheapest I could find.
Pages: « First < Previous 1 ... 491 492 [493] 494 495 ... 596 Next > Last »   Go Up
