October 27, 2026, 01:44:35 AM
485
486
487
488
Topic: What did you do to your Gen7 today? (Read 3801175 times)
0 Members and 44 Guests are viewing this topic.
Reply #7275 on:
November 05, 2013, 12:53:57 PM »
Got a return form for my blue fog bulbs, switching them out for white free of charge.
olecram39
Reply #7276 on:
November 05, 2013, 06:30:46 PM »
Tried taking my catalytic converter off to see if it was clogged and maybe gut it. But it was a fail, i wasn't able to take the bolts off, broke a ratchet in the process. Didn't have the right conditions in my college apartment parking lot to do it.
Reply #7277 on:
November 05, 2013, 06:47:11 PM »
Quote from: Nit3h4wk C0uP3 on November 05, 2013, 12:53:57 PM
Should have gotten yellow for winter.
Ordered some parts
Reply #7278 on:
November 05, 2013, 07:23:16 PM »
Pulled my fog light bulbs out after work, put the old bulbs back in. They're a little yellow
Reply #7279 on:
November 06, 2013, 07:50:29 AM »
Swapped my rear lower control arms with a set of JPower arms (what a bitch it was to take out the old toe arms), swapped my rear upper control arms for a set of stockers (thanks Denny!) and then proceeded to do an alignment. My quickest and straightest alignment to date.
Reply #7280 on:
November 06, 2013, 09:41:56 AM »
Quote from: CrackerTeg on November 06, 2013, 07:50:29 AM
I have to install my lower control arms this weekend. Just curious, what made it a bitch to do? Did you have rusted bolts or is the job a bitch in general?
Reply #7281 on:
November 06, 2013, 09:49:20 AM »
The job is easy when things unbolt properly. When you have seized bolts is when things get difficult. You have to cut those bitches out.
Reply #7282 on:
November 06, 2013, 09:57:38 AM »
New England problems lol...
Confirmed buyers address and will be getting my old mirrors ready to ship out this Friday.
Re: Re: Re: What did you do to your Gen7 today?
Reply #7283 on:
November 06, 2013, 10:24:43 AM »
Quote from: B.R.03EX on November 06, 2013, 09:41:56 AM
The problem is exactly what Tim said.Both of my eccentric bolts for the toe arms were seized to the collar inside the bushing. No amount of PB or air hammering would get them out. Had to break out the sawzall and cut the bolts on either side of the bushing. Every other bolt/nut was easy.
Reply #7284 on:
November 06, 2013, 11:00:55 AM »
Quote from: timot_one on November 06, 2013, 09:49:20 AM
Quote from: CrackerTeg on November 06, 2013, 10:24:43 AM
Gotcha. I'll pick up some replacement bolts just in case. Thanks guys!
Reply #7285 on:
November 06, 2013, 11:54:37 AM »
The main reason why those bolts are hard to get out is because they're seized in the metal collar that's in the rubber bushing. When you hit it with an impact, the metal collar just deflects in the rubber bushing and doesn't get loose.
Reply #7286 on:
November 06, 2013, 12:33:53 PM »
Quote from: timot_one on November 06, 2013, 11:54:37 AM
Um...
Reply #7287 on:
November 06, 2013, 03:38:00 PM »
My main point was the deflection part, not the seizing in the metal collar that you already pointed out. Thanks for playing though.
Reply #7288 on:
November 06, 2013, 04:38:37 PM »
Maybe I should've put the air hammer part in bold as well. Nowhere did I say I used an impact.
Reply #7289 on:
November 08, 2013, 05:07:59 PM »
Ordered new lugs for the RDX, 3000k bulbs for my fogs, got alignment and wheels balanced. Also softened up my struts.
485
486
487
488
