October 27, 2026, 10:25:03 AM
Pages: « First < Previous 1 ... 465 466 [467] 468 469 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3803454 times)
0 Members and 31 Guests are viewing this topic.
« Reply #6990 on: June 23, 2013, 09:22:44 PM »
Took my "I-VTEC Do you?" Stickers off.
Moe
Moe pfffft.
« Reply #6991 on: June 23, 2013, 10:37:14 PM »
Changed the IAC Valve that was causing erratic idling.
« Reply #6992 on: June 23, 2013, 10:45:19 PM »
You can just clean those to fix that problem.
Moe
Moe pfffft.
« Reply #6993 on: June 24, 2013, 09:00:50 AM »
I tried cleaning it, but it didn't help. Once I put the new one in it was idling perfect.
« Reply #6994 on: June 24, 2013, 10:53:39 AM »
Clean my Aem dry flow air filter and pre filter
« Reply #6995 on: June 25, 2013, 06:43:30 PM »
Went to the car wash.....finally.
« Reply #6996 on: June 25, 2013, 10:22:52 PM »
Threw the roof rack on my car.
accordcoupe7
accordcoupe7 pfffft.
« Reply #6997 on: June 28, 2013, 02:53:14 AM »
Washed the cars with the bf
Starting my next little project. Custom decklid. Going to make it a little bigger.
« Reply #6998 on: June 28, 2013, 03:59:05 PM »
testing my ac am sure something blew up some where still not as cold as i expect and i know still needs work also pulling oil pan off to change gaskets major leak going to take pan to machine shop to get a new bolt installed and welded  Cry
« Reply #6999 on: June 29, 2013, 01:54:40 PM »
I would just change the pan. The pan itself is $100 ish and the ultra flange 2 is like $25. Also, looks like you got a slight coolant leak for some odd reason on the left side.
« Reply #7000 on: June 29, 2013, 06:50:57 PM »
the coolant leak was old haven't moved the car much since the oil leak but its been fix i saved the original pan cleaned the old sealant up good the quick valve was good no leaks from it and panted it black also installed some cusco exhaust bushings
« Reply #7001 on: June 30, 2013, 12:53:15 PM »
Which type of liquid gasket did you use?
« Reply #7002 on: June 30, 2013, 04:44:36 PM »
i ended up using hondabond ht
« Reply #7003 on: June 30, 2013, 06:58:00 PM »
Ahh, hondabond is OK. I highly suggest Honda Ultra Flange II. Works WAY better then Hondabond.
« Reply #7004 on: July 05, 2013, 08:56:08 AM »
Finalized the dates for my retro and fog light  install. Bringing the lights and the components on the 14th and going back for the install on the 20th! Also, stopping by the AF body shop after work today to get an estimate on all my body damage.
Pages: « First < Previous 1 ... 465 466 [467] 468 469 ... 596 Next > Last »   Go Up
