August 30, 2026, 02:45:54 AM
Pages: « First < Previous 1 ... 454 455 [456] 457 458 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3684778 times)
HEcreated487 pfffft.
« Reply #6825 on: April 29, 2013, 01:18:18 PM »
Cleaned some parts.  Lips Sealed
« Last Edit: April 29, 2013, 06:49:27 PM by HEcreated487 » Logged
« Reply #6826 on: April 29, 2013, 02:51:20 PM »
I changed the oil and fixed the rear quarter rust over the weekend.. Fought me every step of the way to.
« Reply #6827 on: April 29, 2013, 08:25:43 PM »
So received my replacement aluminum radiator this one is flawless and picked up my poly bushing for the rear sway bar
« Reply #6828 on: May 01, 2013, 12:56:43 AM »
Successfully completed and tested my EPS set up.  It works!
« Reply #6829 on: May 01, 2013, 01:00:01 AM »
Today I started a project and made a mess, and a lot of noise.
fatbastard
fatbastard pfffft.
« Reply #6830 on: May 01, 2013, 07:19:59 AM »
replaced the flexpipe portion of the DC headers. gave up on me after >2 years and more than a dozen track days!
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
« Reply #6831 on: May 01, 2013, 09:17:47 AM »
Ordered some stuff and made a few calls for other stuff.
« Reply #6832 on: May 04, 2013, 12:36:52 PM »
Installed my aluminum radiator
old
New
« Reply #6833 on: May 04, 2013, 08:37:52 PM »
Sanded and painted some stuff then gave her a thorough wash.
« Reply #6834 on: May 04, 2013, 08:53:24 PM »
old
New
Clemente, what are the benefits of an aluminum radiator? I've been meaning to ask you that.
« Reply #6835 on: May 04, 2013, 09:50:20 PM »
Better cooling properties and holds more coolant , My oem was leaking badly so this seem like a good upgrade
« Reply #6836 on: May 05, 2013, 12:54:00 AM »
It's a larger capacity over stock?  Do you know how much larger?
I spent the day tearing the interior out and removing a bunch of old wiring that I will no longer be needing.  I redid the wiring for the security system, but I'm not happy with the results.  I may just completely replace my security system with something new instead.  That way I'm starting with fresh wiring harnesses and can extend the wires as long as I want to get better placement of the components.
« Reply #6837 on: May 05, 2013, 03:24:31 AM »
I once had a dodge neon in which I cracked the radiator. It got replaced with an aluminum one and the problem I had is that during the winter, it would cool the engine so much that the temperature needle would stay on cold and the heater wouldn't work.
« Reply #6838 on: May 05, 2013, 09:03:37 AM »
This aluminum weights 14 pounds over stock when fill with coolant which is 11 pounds on oem for the v6 and the 4cly oem is 10 compare to the aluminum is 12 pounds not sure how to math it out to see how much extra capacity it holds according to there site . This will come in handy for my long road trips in summer traffic
Accord Euro-R
Accord Euro-R pfffft.
« Reply #6839 on: May 06, 2013, 12:54:31 PM »
Ordered more parts!
EBC Ulitmax Slotted Rotors & Green Stuff pads for all 4 wheels.  $383 shipped from AutoAnything.
Either this weekend or next new brakes & wheels will be going on.
"Euro-R" Concept - USDM CM82
Pages: « First < Previous 1 ... 454 455 [456] 457 458 ... 596 Next > Last »   Go Up
