August 30, 2026, 03:02:29 AM
Pages: « First < Previous 1 ... 452 453 [454] 455 456 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3684803 times)
0 Members and 15 Guests are viewing this topic.
« Reply #6795 on: April 18, 2013, 11:50:33 AM »
Changin out my mounts right now and there's a ground wire going to tye PS mount but there's no spot for it on the innovative mount... any ideas where to relocate?
You could drill and tap a hole in the mount.  You can also try a spot directly on your motor.  I'm not as familiar with the J's, so I can't suggest a spot.  You need that ground going to your motor though.
accordguy04 pfffft.
« Reply #6796 on: April 18, 2013, 01:39:27 PM »
Ended up drilling out the hole on the end of the ground and just using the mounting bolts to attach it.
Well... got two out three on.  The PS was a piece of cake.  On the front one the one hole didn't line up... so I just drilled it out a little bit, just enough to get the bolt in.
I didn't do the rear, Its such a pain in the dick.  I stripped the nut on the top cross section of the mount when I tried to get it out.  Not a big deal, the Innovative mounts don't even have those nuts, so ill prolly just end up cutting it.  So I'm just gonna take it to my buddys shop next time I'm home and have him install it.
« Reply #6797 on: April 18, 2013, 02:40:05 PM »
I have found that since the innovative mounts are stiffer than stock, you have less movement and it makes the mounts harder to get in. What I do is loosely bolt in the mount to the sub frame (only about 5-10 threads down the bolt), then run the bolt through the mount to the engine. Then I snug everything up and torque it all down.
accordguy04 pfffft.
« Reply #6798 on: April 18, 2013, 02:54:10 PM »
I tried.  But with three bolts in the front right hole was off...  I'd say no more than an 1/8", so I just trimmed a bit to get the bolt in.
fatbastard
fatbastard pfffft.
« Reply #6799 on: April 18, 2013, 07:47:56 PM »
i admire you guys doing DIY.... me, i just take it to a shop, drink soda, instagram the process, and "learn".  Cheesy
-- Charles --
2005 Honda Accord 2.4L sedan
2011 Subaru STi sedan
« Reply #6800 on: April 18, 2013, 08:27:44 PM »
I get a better sense of accomplishment knowing that I was the one turning the wrenches.  It's also good to know when it's beyond your skill/experience/abilities and have the right shop do the work.
Reputation Power: 18
alpha pfffft.
« Reply #6801 on: April 18, 2013, 08:31:27 PM »
or tools/equipment.  sometimes, it's not worth buying the proper tool if its for a job that is done once.
« Reply #6802 on: April 18, 2013, 08:35:48 PM »
...unless you buy cheep cheap Chinese garbage at Harbor Freight.
accordguy04 pfffft.
« Reply #6803 on: April 18, 2013, 08:44:02 PM »
I like doin it myself and getting the satisfaction as well.  I've been tackling more and more lately and finding that its not as hard as I thought (mainly suspension stuff).
« Reply #6804 on: April 18, 2013, 11:03:19 PM »
That rear mount must be a bitch to get to on the J series. The K is a pain, so I know the J is worse with less room to work with.
I like to be able to say that I built my car myself. Granted, I only "assembled" the motor, but not a lot of people can say that.
fatbastard
fatbastard pfffft.
« Reply #6805 on: April 19, 2013, 02:49:56 AM »
the most complicated thing i did was assemble my valvetrain. that's it! but i dint do the valve clearance myself hahaha
-- Charles --
« Reply #6806 on: April 19, 2013, 07:30:37 AM »
Won't there be some play now when the engine starts moving around when driving?
accordguy04 pfffft.
« Reply #6807 on: April 19, 2013, 08:08:56 AM »
I think it should be ok, its 1 bolt out of 4 and all 4 are cranked down tight.
« Reply #6808 on: April 19, 2013, 08:46:52 AM »
Got new d2s connectors and installed them
DreaminAccord
I <3 My Honda
DreaminAccord pfffft.
« Reply #6809 on: April 19, 2013, 02:03:51 PM »
^^ nice. What ballasts did you go with?
Ben
Graphite Gray / Black Leather
Pages: « First < Previous 1 ... 452 453 [454] 455 456 ... 596 Next > Last »   Go Up
