August 20, 2026, 12:16:57 PM
41
42
43
44
Topic: What did you do to your Gen7 today? (Read 3671887 times)
Reply #615 on:
May 10, 2009, 04:02:52 PM »
Just drove it to work and notice my gas mileage went up after resonator
Reply #616 on:
May 10, 2009, 04:08:12 PM »
washed it.
Reply #617 on:
May 10, 2009, 04:48:07 PM »
wash and wax, vacuum, rims/tire detail, and interior detail..... took me about 3 hours to do
used Meguiars Tech Wax 2.0....came out pretty good
New weather stripping for the sub, and new screws since it wasnt an absolute leak free seal (sealed box)
also reinstalled my infinity kappa 6.5's in the back, had to mount them from the bottom because of the tweeter being too high for the speaker covers to fit, required sawzall haha
came out awesome and sounds sweet as hell,
not a bad sunday....
Reply #618 on:
May 10, 2009, 05:25:44 PM »
Quote from: "NWINNIE34"
i installed my kappas fine. had to cut some of oem grill but its only from bottom so you cant see anything from top.
try that. couse speakers are deep and might limit your trunk space.
Reply #619 on:
May 10, 2009, 07:24:24 PM »
finished up with the tail lights. any of you guys know how to get a glossy finish on tail lights? i wet sanded with 1000 grit, then 2000 grit. followed with medium fine cut cleaner and then wax. but i still have the matte finish. is it the clear coat i used? i used acrylic enamel, should i have used automotive clear coat?
i also blacked out my emblems and front emblem. looks sick.
Reply #620 on:
May 10, 2009, 11:01:00 PM »
Quote from: "dizzle"
dont tell me you painted your tail lights?... if you did that sucks to hear that you painted it, because unless you use traslusent paint with a good amount of clear coat you are never going to get that glossy look on your tails.. is better to just tint your tails with the smoke Vynil and it gives you the glossy look with out having to paint anything..
Reply #621 on:
May 10, 2009, 11:43:10 PM »
lol dont worry, its VHT nightshade. i already had my tail lights smoked already but it was a little still bright.
Reply #622 on:
May 11, 2009, 08:47:32 AM »
Change the rear rotors, and pads. I'll post pictures later of the most worn rotors i've ever see. Car is stopping 100x better, and I have yet to touch the front. Used Brembro Blanks in Hawk HPS i the rear like many members have suggested.
Reply #623 on:
May 11, 2009, 09:11:52 AM »
filled her up last night. put in 15.91 galons in, got 408 miles out of it so 25.64MPG, better then last times and i drove in stop and go traffic so its good. gona try to drive normaly this time to see how much i can save again
Reply #624 on:
May 11, 2009, 11:42:08 AM »
Yesterday I finished up my radiator flush, tightened a coolant hose clamp when I found a leak, cleaned my air filter, and replaced the relay harness and relay for the low beam ballast in the S2000 projector on my PS headlight. Tonight I will be drilling out a bolt that I busted the head off of for my PS headlight bracket, oiling and replacing my air filter, reinstalling my bumper cover, and hopefully connecting my PLX DM-200 OBD gauge after swapping my OBDII port to my KPro ECU.
Reply #625 on:
May 11, 2009, 01:08:20 PM »
Got the ball rolling on some assets that needed to be shifted for me to pick up Levi's TL wheels this weekend and my Ingalls camber kit I plan on ordering.
Reply #626 on:
May 11, 2009, 02:30:18 PM »
went outside and found bird pop on my hood. cleaned that and put wax on that spot.
suleman_manji
Reply #627 on:
May 11, 2009, 02:39:39 PM »
Re-installed my grill. 3M tape on the bottom gave up i guess.
T
X
Squad #
flick
r
fb
[img]http:
Reply #628 on:
May 11, 2009, 04:34:09 PM »
...and my Ingalls camber kit I plan on ordering.
You should get on that one as soon as you can. The Ingalls rear camber kit is on backorder everywhere right now.
Reply #629 on:
May 11, 2009, 05:36:22 PM »
Tell me about it, I ordered them like a month ago already and I'm still waiting!
41
42
43
44
