August 19, 2026, 09:05:51 AM
39
40
41
42
Topic: What did you do to your Gen7 today? (Read 3670324 times)
Reply #585 on:
May 02, 2009, 08:39:31 PM »
I guess that not everyone has a bunch of extra primary wire lying around like me. But the ground wire can be grounded anywhere on the chassis, so it doesn't have to be a long run. You sure it was a ground wire?
yea just fixed it today i had to directly wire it to negative on battery and BaMm back to pissing people off i used some 10gage wiring no more weak connection
Reply #586 on:
May 02, 2009, 09:39:29 PM »
took off the yellow film on the fogs...
Reply #587 on:
May 03, 2009, 07:18:31 AM »
Replaced a burnt D2S bulb.
Reply #588 on:
May 03, 2009, 11:58:22 PM »
drove it to a meet in the pooring rain, then drove it home. Tim now that the axles have broken in and the Tires have been replaced and upgraded, the vibration issue is taken care of, Thanks for the advice on that one. The tires are killer now, went from an all season to a extreme performance summer.
Reply #589 on:
May 04, 2009, 12:52:36 AM »
painted my fog lights. i wasnt liking the offset the fogs put out (that creamy white color) with my 6000K HIDs. it looks good with the front overall. not sure how to change the bulbs, theyre aftermarket JDM (really they are) and the bulb is like connected to the reflector. so ill have to figure out how to replace the bulb when it burns out.
after on the left; before on the right
Reply #590 on:
May 04, 2009, 01:10:09 AM »
Quote from: "cna"
You could have saved yourself some time, trouble, and money by grounding it to the chassis of your car. There's no need to run the cable all the way back to your battery terminal.
As for me, yesterday I changed the oil, tightened up the oil sandwich plate, changed the coolant, found the source of the knocking noise in the rear end of my car, epoxied my vents back in on my center channel pod, and removed some parts from my car. Today I installed my new shortened shift assembly, found the source of the clacking noise in the front end of my car, replaced my plugs, and added some parts to my car.
Reply #591 on:
May 04, 2009, 07:07:21 AM »
Quote from: "dizzle"
You will have to open the assembly to get to the bulbs… I had those fogs on my car before… I replace the original bulb for a yellow one… The out-put did get worse…
Reply #592 on:
May 04, 2009, 07:19:56 AM »
Thinking about if this bumper fixable too take on sanding ,patching and painting the whole red area mest up or should i just get a new one what you guys think?
Reply #593 on:
May 04, 2009, 08:31:21 AM »
Dropped it back off at the body shop for another week of repairs.
Knocturnal84
Reply #594 on:
May 04, 2009, 09:54:39 PM »
zip tied some wires in the engine bay.
painted my intake manifold Gloss Black
Sean Artsen
BrianCrower K24
Reply #595 on:
May 04, 2009, 10:09:28 PM »
lowered my tires pressure today.
Reply #596 on:
May 04, 2009, 11:59:18 PM »
Replaced my old Valve Cover with a new custome painted one I did... replaced all gaskets as well.
Started sanding and painting my old Valve Cover, that Elliot (jade06) will be taking off my hands...
suleman_manji
Reply #597 on:
May 05, 2009, 12:04:05 AM »
cut off my exhaust tip since it looked like shit and was starting to cause a restriction issue
T
X
Squad #
flick
r
fb
[img]http:
unclejud49348
Reply #598 on:
May 05, 2009, 08:59:33 AM »
Finished putting on exactly 20,000 miles in 8 months.
Justin - NHBP Sedan 5AT
(^^ Made by Milan, thanks!)
Reply #599 on:
May 05, 2009, 11:12:07 AM »
So when Elliot's comes off I want his in wrinkle red. Chino, I will pass down mines to you...LOL
PS. You should have used chap stick on the lettering so you would be able to wipe off the paint on the Honda lettering.
You have to do that on mines!!!
Looks F-ing great man.... your skills are getting better bro...
39
40
41
42
