September 29, 2026, 10:46:52 PM
Pages: « First < Previous 1 ... 357 358 [359] 360 361 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3747190 times)
0 Members and 20 Guests are viewing this topic.
Arielit0oo pfffft.
« Reply #5370 on: August 24, 2012, 01:54:45 AM »
Ugh... Right when I get my suspension all right, riding smooth, all good...fucking check engine light comes up, bad cat mad
I have a High Flow Cat Converter, looked it up online and saw another person with a similar problem feeling their exhaust vibrate, which is what mine is doing Sad
Anyone know of a reliable aftermarket cat? before I randomly go buy one at NAPA.
« Reply #5371 on: August 24, 2012, 08:13:48 AM »
magnaflow...
« Reply #5372 on: August 24, 2012, 08:40:48 AM »
Really Tim?  Thats a better size? I just thought 225 since I see most people with them on our Accords.
Wider tire =  moar better
P0420 right?  You have a high flow cat?  I had that code with a high flow cat too.  You can get an O2 sensor extension to fool it and get rid of the code.
« Reply #5373 on: August 24, 2012, 08:41:36 AM »
Ariel go with the Magnaflow like Mike said! That's what I'm getting.... Ima PM you!
« Reply #5374 on: August 24, 2012, 09:24:57 AM »
Decided to put my car for sale and pick up something more practical.
Whaaaa?
Yup.
wow.. it's a fire sale. Z, you're seriously contemplating that legacy wagon?
Legacy GT? Yup.
Z, prepare for leaking axles. THEY all leak. I work on a lot of subarus, and just remember to change out all your fluids at every 30k interval. Brake, coolant, trans, front and rear diff. Also, if you plan on changing the manual tranny fluid yourself, you better pick up a half inch breaker bar and T-70 torx socket.
Thanks for the heads up Thien. I'm actually being practical and going to get the autotragic (I know, I know) since no one else in my house can drive a manual. Plus, it works out if I'm in a drunken stupor and wifey can drive home.
« Reply #5375 on: August 24, 2012, 09:38:38 AM »
Actually, you need that T-70 torx no matter what. Because the front diff drain plug is that size. The rear diff is either a 1/2 drive bolt or 17mm bolt.
« Reply #5376 on: August 24, 2012, 09:51:26 AM »
Good to know.
Back OT, I just posted a FS thread.  Sad
« Reply #5377 on: August 24, 2012, 10:01:03 AM »
Bought an owners manual for 6$ Wink
« Reply #5378 on: August 24, 2012, 11:01:40 AM »
Good to know.
That's not on topic its plugging your fs thread
Arielit0oo pfffft.
« Reply #5379 on: August 24, 2012, 11:02:29 AM »
@Mike: I forgot to mention I currently have a magnaflow one now but I was thinking of getting another.
@Tim: Nice, I'll get that size. Yup, thats the code and I'll see what I do. Prob will replace the cat and if it does it again, then bypass it.
@Billy: Got it!
« Reply #5380 on: August 24, 2012, 11:06:46 AM »
Good to know.
Bullshit! Its what I did to my CM today so it counts.
« Reply #5381 on: August 24, 2012, 01:02:21 PM »
It's because it's a high flow cat. Honestly, you're just wasting your money if you buy another one. P0420 means the catalyst isn't working to efficiency. You get that with a high flow cat because my Magnaflow cat had the same effect.
Arielit0oo pfffft.
« Reply #5382 on: August 24, 2012, 04:36:36 PM »
Already put in an order for a Magnaflow cat, it didnt say it was a high flow cat. I'll throw it one for now.
« Reply #5383 on: August 24, 2012, 06:32:53 PM »
Damn Ariel, did you even try clearing the code first? I got that code once in little over a year, cleared it and nothing came back. Not sure if it makes a difference that I'm running a test pipe tho.
Picked up some 3m rubbing compound for my bumpers. Will try it out this weekend
« Last Edit: August 24, 2012, 06:34:38 PM by Rich01 » Logged
Arielit0oo pfffft.
« Reply #5384 on: August 24, 2012, 06:40:09 PM »
Yeah Rich I tried as soon as the code came up, it came back... Embarrassed. Got one for $70 will be here Monday.
Pages: « First < Previous 1 ... 357 358 [359] 360 361 ... 596 Next > Last »   Go Up
