August 19, 2026, 05:10:51 PM
Pages: « First < Previous 1 ... 280 281 [282] 283 284 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3670806 times)
« Reply #4215 on: January 07, 2012, 09:37:03 PM »
Dude, just get the led lights at auto zone.
« Reply #4216 on: January 07, 2012, 10:31:15 PM »
I know I know, I'm just lazy. I'm about to order some right now actually.  Flippa!
« Reply #4217 on: January 07, 2012, 10:56:59 PM »
Replaced Power Steering pump inlet and pressure line O-rings. I Didn't know that there was a TSB for it. Turns out that there is an issue with the inlet O-ring's rubber. The replacements are orange instead of black. Hope this helps with the whining when it's cold.
Mines where red but am sure the color doesnt matter , it did help with the whining though
« Reply #4218 on: January 08, 2012, 12:37:12 PM »
Start it up this morning, it was about 38 degrees out, and the whining was gone. Normally, at that temperature I would have to warm it up for at least 15min before it stops.
« Reply #4219 on: January 08, 2012, 01:12:00 PM »
Did some touch up work on the spots I got keyed. Going to have to go over it some more as some scratches are extremely deep.
Rushzer0 pfffft.
« Reply #4220 on: January 09, 2012, 11:40:40 AM »
Rolled over to 150,000 miles. Took it in to get an oil and transmission fluid change. Brought my engine stand home from work at lunch, put it in the shed for now. There is a local guy selling 2 k24 shortblocks out of an 06 and 07 accord with less then 100,000 km for $300. Might have to pick one up. He also has a 06 TSX k24a2 head complete for $700 obo. I heard the 06+ TSX cams are the best OEM cams so this seems like a steal to me. I need some opinions would a k20a2/z1/z3 head be better or should I pickup this k24a2 head?
« Reply #4221 on: January 09, 2012, 03:03:48 PM »
The '06 K24A2 intake cam is a little more aggressive than the '04-'05 K24A2 intake cam with 0.9 mm more lift and 12º more duration.  Most people just swap the intake cam on their heads.  The intake valves are +1 mm larger on the '06 K24A2 head also.  If you're planning on doing any port work on the head, then get a K20 VTEC head.  The K24A2 heads have had some issues with porosity in the casting which causes coolant to "weep" into the intake bowls.  I think it all depends on how you're planning on building the motor and what you're building it for (n/a, turbo, sc).
B.R.03EX pfffft.
« Reply #4222 on: January 09, 2012, 04:13:45 PM »
Pulling my front end apart again. I've got moisture in my driver side headlight. I must not have sealed it properly the last time I took it apart.
Rushzer0 pfffft.
« Reply #4223 on: January 09, 2012, 04:42:43 PM »
I'm building the motor for boost, I've pretty much settled on a Rotrex unit to supply it, looking for 400-500 hp.
K24/20 frank
87.5mm Weisco Pistons 9.5:1
Manley Turbo Tuff Rods
Supertech valvetrain
ID1000 injectors
RBC IM
SSR,ASP,Rcrew or similar exhaust manifold
3" exhaust
Upgraded fuel system (pump,lines,regulator,rail etc)
Running on meth and the crappy 91 octane we have here :p
And of course other assorted things, wastegate,bov,intercooler,assorted gauges, sensors etc...
From what I've read I should easily be able to hit that mark with OEM cams and a head with little to no head work. Thanks for the info Tim.
Daheavyking
Daheavyking pfffft.
« Reply #4224 on: January 09, 2012, 04:58:28 PM »
Bought a new mirror for the passenger side.  Someonce stole my fu**ing mirror while it was parked!!!!  Hope they get herpes and it burns when they pee!!!!!!!
« Reply #4225 on: January 09, 2012, 05:01:28 PM »
That's the Bronx for you.
Daheavyking
Daheavyking pfffft.
« Reply #4226 on: January 09, 2012, 07:38:16 PM »
^^^  True but I litteraly got a car wash 2 hours before hand.  I feel violated Sad
B.R.03EX pfffft.
« Reply #4227 on: January 09, 2012, 09:36:52 PM »
I did a drain and fill on my transmission today. Something kind of bothers me though, everything I've seen and read says to fill the 6 speed transmission with 2.3 quarts of Honda MTF but when I drained it, at least 3.5 quarts came out of it. I put 2.3-2.5 quarts back into it but I haven't ran it yet. Did someone put way too much in before me and I should stick with the 2.3 quarts or should I put more in to match what was in there before?
« Reply #4228 on: January 10, 2012, 01:02:32 AM »
I've always filled until the oil starts to come out of the fill hole. That's the general rule when it comes to manual trannies. I could be wrong.
Arielit0oo pfffft.
« Reply #4229 on: January 10, 2012, 01:30:39 AM »
Oh... Was it a black passenger side mirror? Because my dad bought me a passenger side mirror today in the Bronx LOL
Pages: « First < Previous 1 ... 280 281 [282] 283 284 ... 596 Next > Last »   Go Up
