August 22, 2026, 01:53:17 AM
100
101
102
103
Topic: What did you do to your Gen7 today? (Read 3674116 times)
Reply #1500 on:
September 12, 2009, 11:55:41 PM »
Replaced my blown dome light bulbs
Reply #1501 on:
September 13, 2009, 01:57:06 AM »
Replaced my axles, replaced my shift cables, pulled my front suspension apart to clean out the threads on my Basics, and bled my brakes. Actually Ken did all the work and I just watched. Too bad the new axles make my car shake like a motherfucker now. Cheap ass Chinese parts. Now there's an 03 Accord sedan for sale. Fuck this goddamn car.
Reply #1502 on:
September 13, 2009, 10:29:18 AM »
Reply #1503 on:
September 13, 2009, 11:14:16 AM »
Tim are your new axles missing there balancer rubbers. I had that same issue with my integra. They gave me civic axles without the balancers eventhough they fit the integra, they vibrated the car. Just something to look into.
Reply #1504 on:
September 13, 2009, 08:21:49 PM »
Reply #1505 on:
September 13, 2009, 08:23:34 PM »
Adjusted my headlights and still seems like I need to go higher. Damnit.
Reply #1506 on:
September 13, 2009, 09:11:44 PM »
Lets see today, I yanked off my valve cover to pull out some broken valvetrain pieces (timing plates) overlooked the valvetrain about 30x with Paul for remains of the plates.
Adjusted the Lash on my valves(Well I tried, Paul did actually) replaced a missing valve rocker nut(Caused an extremely gross ticking sound) Replaced the valve cover, installed a magnetic drain plug and changed my oil.
Theeeen! adjusted a few parameters in K-Pro (gear ratios, idle and temp compensations and ignition timing) then went for a few datalog runs and tried to reduce my knock count, Darkseid's pushing close to 1100 miles now and with the Valve adjustment I can feel the difference in compression and it feels like it did at the beginning of the week.
All in all a pretty good day, Im going tuning tomorrow with my RSX Buddy to reduce the knock count
JohnnyG123
Reply #1507 on:
September 13, 2009, 09:59:10 PM »
changed my oil, trans fluid, coolant, and serpentine belt and rotated my tires. car should be good to go for a long while now.
'10 Accord EX-L V6 6spd
Reply #1508 on:
September 14, 2009, 09:41:36 AM »
Just ordered replacement front window tint since I fucked it up last time. Should be here in the next couple of days.
Reply #1509 on:
September 14, 2009, 12:38:15 PM »
Just finished washing the ride and trying to buff out a nice scratch I recieved over the weekend.... didn't work, it is too deep. Someone did it on purpose I know they fucking did! Well also took the car for a quote on the damages and other minor scratches and to paint the whole ride @ $1600 plus tax. This by far to me is a great price. I will probably get this done in the spring when I do my 06-07 front conversion. Car is also now runing great after changing that secondary O2 sensor last weekend. I am no longer dumping fuel.
Reply #1510 on:
September 14, 2009, 04:42:30 PM »
redid my speaker grill.
from this
to this
just cleaned wheels and vacumed inside
Reply #1511 on:
September 14, 2009, 05:51:05 PM »
priced new tires....
so expensive.....
Reply #1512 on:
September 14, 2009, 09:32:44 PM »
Just ordered a PnP upgrade harness for my HIDs from The Retrofit Source. Should've done this a long time ago. Live and learn.
Reply #1513 on:
September 15, 2009, 03:36:02 PM »
finally changed my O2 sensor and cleared the code. no CEL so far.
Reply #1514 on:
September 15, 2009, 04:36:03 PM »
just ordered some new shoes
215/50/17 Falken ZE-912's
100
101
102
103
