April 04, 2026, 10:48:23 PM
Strut/Spring combination
Topic: Strut/Spring combination (Read 7855 times)
Autodesigner3
February 20, 2010, 06:10:16 PM »
I'm getting ready to buy a set of Tokico HP blue struts with springs but I need to be assured of the clearance. I want to get Neuspeed Race Springs which have a 2.25" front and 1.75" rear drop, will I rub on 19's with 235/35 tires? My 2nd choice was Tein S.Tech with a 1.8" front and 1.3" rear drop which I know a lot of you have and do clear but I want the biggest drop possible.
Re: Strut/Spring combination
February 20, 2010, 06:15:23 PM »
S tech's are good springs, I had them on stock shocks prior to getting my Tein SS coilovers. The drop is really nice, so I'd recommend the teins. I never rubbed with my 18's so I dont know how they'd affect 19's?
February 20, 2010, 08:25:52 PM »
Well, what are the full specs of the wheels? With the Race spring drop, you may get away with a slight fender roll..
February 20, 2010, 08:37:26 PM »
Only way to tell you if you will rub is to know the width and offset of the wheels.
Autodesigner3
February 20, 2010, 10:57:23 PM »
Quote from: "Milan"
well my rims are 9" wide and I measured from the flat surface where it touches when mounted to the inner most part of the rim and it was 6"...i don't know how to figure out the offset...hopefully that tells you what it is
February 21, 2010, 01:02:41 AM »
the offset will be on the wheel.. what wheel is it?
9" wheel. why a 235mm tire?
Autodesigner3
February 21, 2010, 08:43:53 AM »
Quote from: "alpha"
well the wheel says M608 19x8JJ ET35 so 35 offset?....i measured the wheel myself and it actually measured 9"
February 21, 2010, 10:23:35 AM »
I think the wheel width is measured from inside the outter beads...
February 21, 2010, 11:06:29 AM »
Offset is the distance from the mounting holes to the center of the rim, easy way to measure this is measure from the mounting holes to the far end of the wheel, and then subtract half the wheel width
And your offset is +35
February 21, 2010, 11:53:00 AM »
If you really want the maximum drop without rubbing, you may want to consider a set of adjustable coil overs instead. That way you can go as low as you want and adjust it if you rub.
Autodesigner3
February 21, 2010, 12:19:20 PM »
thanks guys..now i know my offset too...I think I'm just gonna get the TEIN S.Tech just to be safe, I think it'll still look good
February 21, 2010, 01:04:39 PM »
Quote from: "Autodesigner3"
Quote from: "alpha"
Yes, your offset is +35. Your wheel is 8" wide, not 9".. This diagram helps explain wheel measurements:
http://www.tirerack.com/wheels/tech/tec ... ?techid=95
On your wheel, a 235mm tire will be good.
There are multiple things you can do to prevent rubbing. As Tim suggested, you can get coilovers to adjust ride height. You can also do some fender mods and you can play with camber settings.
If you want the Race springs, I wouldn't be afraid to get them. The coupe is more forgiving than the sedan and with those wheel specs, you should be fine. You may have to do a slight fender roll.
Autodesigner3
February 21, 2010, 10:58:59 PM »
Quote from: "alpha"
Quote from: "alpha"
thanks i'll go with the race springs then i'll just do the fender roll if needed
Autodesigner3
March 03, 2010, 10:30:29 PM »
well my new toys arrived and here we go....went with the tokico struts and neuspeed springs...say goodbye to wheel gap, 6.5" Alpine Type S component speakers, JL Cleansweep (already had but needs reinstalled), and OBX oil catch can....I had a TSX im too but I installed that last week cause I couldn't wait
March 04, 2010, 07:59:48 AM »
Those will drop your car without issues. Gen's coupe is on the same springs and we're running 18x8" wheels with a 30mm offset and a 225mm tire. Your set up with a wider tire but less aggressive offset should be about identical. We didn't roll the fender but then again it's running more camber in the back since we didn't get a camber kit for it yet.
