June 18, 2026, 11:53:45 AM
Author Topic: Door Rattling  (Read 16902 times)
« on: February 13, 2010, 04:21:46 PM »
I took of the front door panels in an attempt to figure out what's causing so much rattling, and it turns out that it's nothing actually in the door panels. It's the two white layers of plastic tarpish stuff glued onto the door itself. Whenever I play music, the two pieces hit each other (or something behind them that I can't see) and cause this very annoying rattling. I taped it up a bunch to try and reduce the rattling, and it works for low volumes, but once I crank up the sound, the rattling comes back. Could I get some advice in how I should tackle this? I'm going to be hopefully ordering some B-Quiet dynamat material soon, so that should help, but I'd like to figure out something while I still have the panels off.
Reputation Power: 17
Abailey4 pfffft.
« Reply #1 on: February 13, 2010, 04:56:50 PM »
I've got rattling inside my passenger side door as well. Mine actually sounds like the window is shaking around in there but it operates find. It only does it though when I'm driving, bass doesnt affect it. It's been like that for a while, I'm just too lazy to take the panel off to see what the culprit is.
« Reply #2 on: February 13, 2010, 05:15:49 PM »
God damnit. After all that work, it turns out that it's actually the wood trim that's rattling. I found that if I leave the main support screw off, it doesn't rattle. Right now I'm wondering if I should leave it off or figure something else out. Without that screw, the door panel could be more prone to popping off. Ugh.
Edit: There was no way that I could reach the underside of the wood trim without having to break stuff, so I ended up leaving these support screws out. The interior door grip areas are a little more flexible, but I don't think the door will pop off. Let's hope and see. As far as rattling goes, I got most of it out. Lucky me though, as I'm listening for rattles, I hear more coming from the tweeters now. Oh joy.
« Reply #3 on: February 13, 2010, 06:46:52 PM »
That's kind of the problem with rattles. As soon as you think you have it beat, more pop up. Good luck with your hunt Jeff. I'm too old and lazy to try and find rattles. I just learned to deal.
« Reply #4 on: February 13, 2010, 06:55:47 PM »
Ohhhhhh.  That's why you were asking me about the b-quiet the other day.  Did you remove the weather shield (white plastic tarp thing-a-mingy) and see what was behind it?
I'm like Z, except I'm older and lazier.  My car rattles like a motherfucker and new ones always pop up.  Considering the number of times I've taken my interior apart and the amount of power and number/size of subwoofers I had in previous stereo set ups, there's bound to be at least one or two rattles.
« Reply #5 on: February 13, 2010, 06:56:14 PM »
Thanks Z. I used bubble wrap to insulate certain areas of the door. I just squished it in between the two plastic tarp layers, lol.
« Reply #6 on: February 13, 2010, 07:05:38 PM »
Hey, if it works and its cheap, fuck it right?
Tim, you might be older chronologically but I highly doubt you could feel as old and lazy as I do. I have kids.
« Reply #7 on: February 13, 2010, 11:30:06 PM »
Jeff, bubble wrap will not do.  I would recommend that you use proper materials to reduce vibration.  The bubble wrap is just stuffed in there, and while it may separate the weather seal, it's not really a reliable solution.  FWIW, I removed mine a while ago.
« Reply #8 on: February 14, 2010, 09:33:28 AM »
Yeah, I know that it's a really jury rigged attempt to get rid of the rattling, but once I can actually get some of the B Quiet stuff you recommended me, I'll probably be more motivated to do a better job, lol. I just wanted to do something that worked.
Paulius005 pfffft.
« Reply #9 on: March 03, 2010, 12:28:59 AM »
I realized that if you lube up the back of the door panels they stop rattling, i just put some grease on areas which seemed like they would be causing the problem and no more rattles from the doors... now if i can make my damn glove box stop sagging...
Paulius San Jose, CA
« Reply #10 on: March 03, 2010, 07:52:25 AM »
Grease in the door panels? You mean lubing up rub points?
« Reply #11 on: March 03, 2010, 08:30:37 AM »
Quote from: "Paulius005"
Mine sags a bit to let me know if you find a solution to this.
Paulius005 pfffft.
« Reply #12 on: March 03, 2010, 01:27:11 PM »
Yeah on the backs of the door panels... made that stop making noises, so I'm content.
« Reply #13 on: March 03, 2010, 10:41:01 PM »
Good to know. I'm assuming you used silicone grease?
Paulius005 pfffft.
« Reply #14 on: March 08, 2010, 07:47:14 PM »
Yes sir.
On the glovebox sagging issue, there are two screws on the bottom of it that you can unscrew push up the glove box using some muscle and then screw back it...helped a bit, but not much.
