September 30, 2026, 03:17:35 PM
Pin Striping Removal
Topic: Pin Striping Removal (Read 5663 times)
February 10, 2010, 10:54:05 AM »
What's a good way to remove this without scratching the paint? Mine is starting to flake off in some areas.
Re: Pin Striping Removal
February 10, 2010, 11:22:38 AM »
same thing happened to me recently, i used a hair dryer to heat it up and then started using my finger nails to peel it away. i then used some invisible glass to wipe away any residue. then clay-barred the entire car the next time i washed it.
February 11, 2010, 12:47:04 PM »
I might be wrong, but I would suggest using a heat gun with great care.
February 11, 2010, 12:48:53 PM »
Quote from: "Icebox"
hair dryer
hair dryers and heat guns are two completely different things, a hair dryer puts out far less heat and will not hurt the paint.
February 11, 2010, 01:16:50 PM »
A heat gun would be much faster than a hair dryer but, you would have to be careful.
February 11, 2010, 01:29:51 PM »
I didn't even use heat. I just started peeling it with my fingernail. It was, however, a pain in the ass because it would break off every inch. If I had to do it again, I'd definitely use a hair dryer.
February 11, 2010, 02:15:16 PM »
yours is a decal, i take it?
February 11, 2010, 02:21:22 PM »
all of the stock pin stripes are basically a sticker, once heated up, they pull right off.
February 11, 2010, 04:55:13 PM »
I let mine bake outside for a while then soaked it in GooGone. That seemed to work pretty well
