August 13, 2026, 01:15:19 PM
Author Topic: Hybrid Mirror Wiring Guide  (Read 61483 times)
Pascal
Pascal pfffft.
« Reply #45 on: February 28, 2014, 09:45:28 PM »
With parking lights of, it's all good, but with them on, that would make the LED's go OFF when the turn signal be ON. Alternating with the normal turn signal. I don't know if you understand me.
Parking OFF
Turn signal OFF  --> LED OFF
Turn signal ON  --> LED ON
Parking ON
Turn signal OFF  --> LED ON
Turn signal ON  --> LED OFF
« Reply #46 on: February 28, 2014, 09:49:55 PM »
Yeah.  That's how I expected them to function.
Pascal
Pascal pfffft.
« Reply #47 on: February 28, 2014, 09:57:00 PM »
well that would look odd to me, but if it is the way you want them to be, it would work. My way makes it blink at the same time, which makes it look more like oem, but that's tastes.
Pascal
Pascal pfffft.
« Reply #48 on: March 01, 2014, 09:59:27 AM »
My way would make the LED's light up when unlocking/locking the car too since the power comes from the parking lights. I still don't get your thing with the diodes and backfeeding power into the headlights though.
« Reply #49 on: March 01, 2014, 12:35:41 PM »
Okay, I was thinking about your wiring diagram and relay set up all wrong.  I kept thinking that the signal wire for the relay were after the MICU and getting an intermittent signal instead of the constant signal that would be coming from the switch before the MICU.  Now I understand your set up.  I think the only thing I would change is to use 1 relay for the hazard light switch and put it before the turn signal relays.  I'd only do that to simplify the set up.
Follow me on the backfeeding though.  If you follow the current path on your wiring diagram, there's 12v going to the mirror LED's when the parking lights are on.  Correct?  You also have the brown wire labeled left/right turn signal branching off from that signal path between the relay and mirror.  Does that wire go to the turn signal bulbs in the headlights?
If it does, then under normal circumstances, when you have the parking lights on there would be 12v going to the turn signal bulbs.  That's what I mean by backfeeding.
Pascal
Pascal pfffft.
« Reply #50 on: March 01, 2014, 02:16:46 PM »
Yeah you are right about the way I did it, the relays are for an exception when not to use parking light current . And yeah I haven't thought about putting the hazard relay before the other two. I just thought about after that only one wouldn't work or needing a double contact relay, I'll change that ! And for the diodes I'll need 3 if I get it right . One before all relays on the parking light wire and one on each turn signal wire ( left and right ). It is an art beeing able to simplify at its best a relay diagram Wink  Cheesy
If I am right and you don't see anything else I'll modify it and post it again. What software are you using ? Anything is better than ms paint !
« Reply #51 on: March 01, 2014, 08:25:43 PM »
I will draw up a diagram. You would only need 2 diodes. One for each turn signal.
You'd be surprised what I'm using to make those drawings.
« Reply #52 on: March 02, 2014, 11:17:36 AM »
Visio?
« Reply #53 on: March 02, 2014, 12:40:27 PM »
Crayons, paper towels and a flatbed scanner.
Pascal
Pascal pfffft.
« Reply #54 on: March 02, 2014, 12:50:35 PM »
Could be visio. Looks a bit like it with the grid in the background. Thought it was software purposed for electrical drawings.
« Reply #55 on: March 02, 2014, 03:35:51 PM »
Nope. You guys are far off.
« Reply #56 on: March 02, 2014, 04:55:07 PM »
Got it now. Colored pencils, low grade copy paper and a cell phone camera.
« Reply #57 on: March 02, 2014, 08:39:36 PM »
Excel
olecram39
olecram39 pfffft.
« Reply #58 on: May 14, 2014, 01:15:28 PM »
FYI this works exactly the same for the tsx mirrors so maybe change the title to hybrid and tsx mirrors? . I just did mine, thank you Tim
Pascal
Pascal pfffft.
« Reply #59 on: September 10, 2014, 10:43:49 AM »
I am in the process of making a custom PCB for a underskirt VIP puddle lights and turn signals and for the hybrid/tsx mirrors. Would anyone be interested into one of these ( a version only for the mirrors ) ?
