June 14, 2026, 10:40:33 AM
which coilover and y???
Topic: which coilover and y??? (Read 22015 times)
Bwek
Re: which coilover and y???
Reply #30 on:
April 09, 2009, 12:27:57 PM »
Quote from: "fabulous010"
why is the neuspeed cup kit soo cheap??? how good are they?
you need to hurry up and drop your car broheim and get that rear sway put in
jdmaccord
Reply #31 on:
November 16, 2009, 03:41:34 PM »
1. Does anyone know if Tein SS sits lower thenTein Basic if coils are slammed all the way down?
2. Does Tein Basic sit lower on a J series vesus a K series?
Reply #32 on:
November 16, 2009, 11:16:48 PM »
For the record. All of this information is available on Tein's website.
BASIC
ACCORD CM5 03-07 4cyl 4dr
Ride Height
Front (mm/inch) ~ -61/-2.4
Rear (mm/inch) ~ -56/-2.2
Ride Height Adjust Range
Front Max-Min (mm/inch) ~ -6/-0.2 to -98/-3.9
Rear Max-Min (mm/inch) ~ -33/-1.3 to -79/-3.1
ACCORD CM6 03-07 6cyl 4dr
SS-P
Ride Height
Front Max-Min (mm/inch) ~ 4/0.2 to -94/-3.7
Rear Max-Min (mm/inch) ~ -43/-1.7 to -77/-3
Ride Height
Reply #33 on:
November 17, 2009, 07:38:34 AM »
Quote from: "jdmaccord"
If your looking to get even lower than you are now you may want to give K sport a look. I'm not sure of the quality but, I've heard that can go extremly low.
jdmaccord
Reply #34 on:
November 17, 2009, 10:48:21 AM »
i've noticed here in Boston acouple of J series 7th Gen both coupe and sedans with Tein Basic sit lower in the rear then my K Series. Same coilover setup installed at the same location with no modification done to them(i.e. cut coils). But they both riding on 20's while i'm on 19, maybe that could be the issue
Reply #35 on:
November 17, 2009, 11:34:26 AM »
It may be the fact that the tire is a little larger giving a lower look. It could also be the weight of the J30 compared to the K24. Those numbers on Tein's website seem to just be a general statement instead of concrete numbers.
Reply #36 on:
November 17, 2009, 02:13:04 PM »
that shouldn't have an effect on the ride height of the rear.
Reply #37 on:
November 17, 2009, 10:17:27 PM »
Maybe he was only looking at the front end.
