September 22, 2026, 10:05:43 AM
Power Windows and Battery
Topic: Power Windows and Battery (Read 12170 times)
Accord1234
December 28, 2009, 12:34:03 AM »
Last Saturday my car didn't start agian. Not the first time I had to jump start it. Everyones telling me it can't be the battery cause I had just changed it only a year and a half ago. So I jumped it, got it running and put the alternator tester on it. Charging at 14.5v perfect. So I said fuck it, tired of getting stuck so I went to get a sears gold battery. I had one of those optima batteries and was pissed of it went and that it only comes with a 12 month warranty and cost me close to 200 bucks. So I figured the sears with the 3 year warranty is good enough.So I looked at the one for a 05 Accord Ex 4cy and then put the one for an Accord Ex 6cy next to it. The one for the 6cy had way more cold cranking amps and was almost double in size. I figured ahh fuck it the bigger the better. So I bought it, took it and and long behold had to cut the battery tray. Then of couse the tie down rods were to short to reach over. Wound up just throwing the whole battery box and shit away and tieng it down like that. Connect everything, car starts beauitifully. Everything seems fine untill I go to roll down the window. It goes up and down perfect but not automatic anymore. I have to hold it the wholw way down and up. Any ideas why and how to get it to go on its own.
Thanks Tommy
Re: Power Windows and Battery
December 28, 2009, 01:09:26 AM »
There is a learning procedure for the auto window feature. You'll have to hold it down all the way, and then hold it up all the way. Then it should reset and be working again.
FYI, OPTIMA is not the same quality they used to be, so I would not recommend buying them now.
Accord1234
December 28, 2009, 08:15:12 PM »
ok,I'll try that. didn't realize it was so simple. Guess I found out about the optima batteries the hard way. Thanks
December 29, 2009, 02:20:40 AM »
Wait, is there any alternative to Optima batteries now since you say the company's quality is not what it used to be?
January 02, 2010, 08:32:57 PM »
Read
this thread
for a discussion about which batteries haven't turned to shit like Optima did when they got bought out.
Accord1234
March 08, 2010, 08:15:21 PM »
That learning procedure only worked for the drivers side. Still can't get the passenger window automatic again. I'll try it again
March 08, 2010, 08:30:32 PM »
Quote from: "Accord1234"
In my car only the Driver window is auto. Thought all 7th Gens were like that.
March 08, 2010, 08:32:34 PM »
You have an automatic passenger side window? Interesting. Do you still have the owner's manual for your car? It may say something in there unless you have something aftermarket installed.
March 08, 2010, 08:36:38 PM »
Quote from: "CYANiDE"
+1
As far as I know only the driver side is automatic dude!
Accord1234
March 08, 2010, 10:44:31 PM »
Am I loosing it already. I thought the drivers was auto up and down while the passenger was auto down only. If not I must be thinking about another car.
March 08, 2010, 10:57:08 PM »
Only the DS window is automatic unless you have a one touch module like the one DEI makes.
March 09, 2010, 08:53:08 PM »
I knew I wasn't going crazy when he posted both sides being auto.
phunctional
March 09, 2010, 10:16:54 PM »
this didnt work at all for me
CM82
March 11, 2010, 04:44:11 PM »
Probably because it only applies to the DS. You didn't try doing the PS as well, right? If that's the case, it won't work.
phunctional
March 11, 2010, 04:58:50 PM »
if your talkin to me i mean the driver doesnt work either
CM82
